sdwhite Posted January 27, 2006 Report Posted January 27, 2006 Rocking the engine forward was a pain on my '93 Cutlass Supreme but after doing so, there was plenty of room to work...there would be no reason to go to the serious hassle of disconnecting the battery and pulling the alternator. I have NOT been able to get the engine forward enough on my '95 cutlass supreme to get the bolt into the second wishbone mount hole. Quote
GutlessSupreme Posted January 27, 2006 Report Posted January 27, 2006 make sure the park brake is on and tranny is in neutral. Quote
herb427sc Posted January 27, 2006 Report Posted January 27, 2006 The easiest way to change spark plugs is: LET SOMEONE ELSE DO IT.. Then all you have to do is: OPEN YOUR WALLET... Quote
Supreme Cutlass Posted January 27, 2006 Report Posted January 27, 2006 The easiest way to change spark plugs is: LET SOMEONE ELSE DO IT.. Then all you have to do is: OPEN YOUR WALLET... Wimp Quote
THe_DeTAiL3R Posted January 27, 2006 Report Posted January 27, 2006 I posted a writeup on the EASIEST way to tilt your engine. It's in my sig... Quote
