cutlass_driver91 Posted January 22, 2006 Report Posted January 22, 2006 i have this lousd clicking clacking noise when i ONLY turn to the right i spun the tires in loose gravel real quick and ever sense i have the weird loud clicking noise from the right side..........dose the 91 cutlass conv. have a lower tranny mount or a lower eninge mount that might have broke.....hell i graduated from nascar tech and i cant figure this one out Quote
3pt1lumina Posted January 22, 2006 Report Posted January 22, 2006 Isn't it called a CV shaft? not a CV joint? I don't really know, honestly. When I asked for a CV joint at a parts store, they didn't know what I was talking about. They knew what a CV shaft was though. I believe that is what the noise is as well. Quote
R Dubya Posted January 22, 2006 Report Posted January 22, 2006 actually a joint is part of the shaft. Quote
Rocketman Posted January 22, 2006 Report Posted January 22, 2006 The shaft would technically be the axle, which has a CV joint at each end. There are Inner and Outer CV joint. CV stands for Constant Velocity, and it allows the axle to bend at an angle and still transfer power. There are several different styles, but the most common uses 2 slotted racesways with a set of ball bearings it it. When the raceways become worn, they snap as the bearings catch and produce a clicking noise. Hope this helps :? Quote
Crazy K Posted January 22, 2006 Report Posted January 22, 2006 When I asked for a CV joint at a parts store, they didn't know what I was talking about. They knew what a CV shaft was though. Lucky You! You have experiecned the JOY of ignorance! I hate parts people who don;t know how to help. CV joints Can be rebuilt, and you can buy rebuild kits, but the cost of a new shaft is cheap enough I would just replace the shaft. Quote
R Dubya Posted January 22, 2006 Report Posted January 22, 2006 The shaft would technically be the axle, which has a CV joint at each end.:? Technically there is only one CV joint (outer). The inner is called a "tri-pot". We should just stick with axle assembly. 8) Quote
Crazy K Posted January 22, 2006 Report Posted January 22, 2006 The shaft would technically be the axle, which has a CV joint at each end.:? Technically there is only one CV joint (outer). The inner is called a "tri-pot". We should just stick with axle assembly. 8) correct!!!!!!!!! How about... CV axle shaft? Quote
White93z34 Posted January 22, 2006 Report Posted January 22, 2006 i always refered to em as, half-shafts, axles, etc, and the joints are the CV joints. Quote
cutlass_driver91 Posted January 22, 2006 Author Report Posted January 22, 2006 nope sorry guys i replaced both left and right cv axles/drive axle's and the noise is still there(3 months ago) i thought it was just a rock in the under craaege but nope could it be the starter hiting the flyweel??? the one mechainc said it was the LOWE RIGHT TRANNY MOUNT.....and my dealer said there ISNT a lower right tranny mount but only a lower right eninge mount so what in gods green earth can it be????? Quote
Crazy K Posted January 22, 2006 Report Posted January 22, 2006 umm does the car have hub cap? If so take em off and take it for a test drive. if it still clicks... try this. Open the hood with car in park, parking brake off, wheels straight ahead. grab the car by the upper radiator support, and start rocking the car hard until the engine is jerking against the engine mounts. If you are worried about the car rolling away, place a block a few inches away from one of the tires, btw. so it has room to rock. repeat with the wheel turned far left and right. See if you can imitate and isolate the sound. I'm thinking check: lower control arm mounts and bushings tie rods(inner and outer) CV(just is case, replaced before of after the wheel spin???) and engine mounts(both lowers and the dogbones) Quote
cutlass_driver91 Posted January 22, 2006 Author Report Posted January 22, 2006 crazy_k the tie rods are what i am thinking because it only happens when i turn right and on the gas....but as soon as i let off the gas it stops...thats why i was asking abot the lower right tranny mount.......cause it has the 4T60 hydamatic tran in it and one of the mounts are broke the mechainc at minake said it was the lower right transmisson mount...................... Quote
Guest TurboSedan Posted January 22, 2006 Report Posted January 22, 2006 the mechainc at minake said it was the lower right transmisson mount...................... the mechanic was probably looking at it the wrong way there is only one transmission mount and it is on the left side. have you checked the CV boots (since you've replaced them) to make sure they are not ripped or have become unclamped? Quote
cutlass_driver91 Posted January 22, 2006 Author Report Posted January 22, 2006 the CV axles are in 100% good shape no tears no nothing would it be better just to change ALL the eninge/transmisson mount and then see what happens....cause i dont think it can be the rack' n' pinion or anything like that Quote
Crazy K Posted January 22, 2006 Report Posted January 22, 2006 do my rocking test and see what happens! Quote
3pt1lumina Posted January 22, 2006 Report Posted January 22, 2006 okay if you think it's your tie-rods...jack the car up and shake the front wheels from side to side. If there is excessive play then bingo!... If you shake them up/down that's checking balljoints which I doubt is your issue, but might as well check them as long as the car's off the ground. Quote
cutlass_driver91 Posted January 22, 2006 Author Report Posted January 22, 2006 okay...so is everybody sure that it is not the lower right eninge mount and the starter or anything is hitting up aginst the flyweel or anything when i make a right turn.... Quote
3pt1lumina Posted January 23, 2006 Report Posted January 23, 2006 It may be...but I honestly don't think so. If it's not the CV joints, then try tierods. For shits and giggles, are the lugnuts on the wheels tight? I had a friend that didn't tighten them down all the way once and he heard a clicking sound and that was it. Quote
sdwhite Posted January 27, 2006 Report Posted January 27, 2006 I'd also check the tie rod end. Had that happen with my '93 Cutlass Supreme a while ago. You might consider a wheel bearing, too, but when that went bad it was pretty quiet. Quote
LuminaMan93 Posted January 27, 2006 Report Posted January 27, 2006 I had the same problem on my Lumina. It made a clicking noise only when I made a right turn. Mine turned out to be the starter. As soon as I replaced it the noise went away. Quote
jdcutty Posted January 28, 2006 Report Posted January 28, 2006 I was thinking wheel bearing, too. Quote
