GrandPrix1988SE Posted January 19, 2006 Report Posted January 19, 2006 Car is a 1988 GP Since the Turn Signal Switch is bad, and it's got the tilt column "wobble" I have to tear it apart anyway, and I'd love to also add cruise. What all do I need form the 'yard to do this? Quote
Robby1870 Posted January 20, 2006 Report Posted January 20, 2006 You'll need the turn stalk with cruise and the 4 wires that come with it, make sure and unplug those wires from under the steering wheel from that big connector. You'll also need the cruise module itself, throttle linkage, vacuum line, and the wiring that goes from the cruise to the ECM. Im not sure if a non-cruise throttle body has the extra attachment for cruise, you'll just have to look. Might be more, but thats all I can think of right now Quote
Crazy K Posted January 20, 2006 Report Posted January 20, 2006 don;t foget the vaccum acctuated brake cut off. Above the brake pedal... earier cars have it, later ones have an electric release. Do you have a donor car in mind? Quote
GrandPrix1988SE Posted March 2, 2006 Author Report Posted March 2, 2006 Last sun I found a 1994 with a bunch of goodies on it, incl. the cruise module. Are these different? There was also a 4 door 1990 GP with cruise as well Quote
