a clip or sumfin on a rotor
i am not sure but is there like a clip or sumthing that goes on teh rotors so it doesn't like wiggle i am not sure my dad said this when i changed teh rotors so i am unsure
i was like unsure my dad siad there should be like on teh stud to hold teh rotor and i was like i doubt it and he insisted that there was so iunno
Nope, there isn't, I can guarantee that one!
The rotor is clamped down to the hub by the wheel. When ya tighten them lugs, the rotor can't go anywhere.
They are called "Anti- rattle clips" I had to repalce them on my 88 olds cutlass supreme. If there gone your roter goes "Knock knock when u drive, it slows down when you go fast, and it goes away whebn you hit the brakes. They are like $2.00 CDN!!!!
WHAT WHAT?!!! YES! I hope that fixes my problem. Just recently my rear right caliper makes a pop when I hit the brake, then rattles when I release it! I removed the caliper, the sliders are fine, I put some brake quiet on the back of the inside pad and it did shit....it does this when ive driven for a while, NEVER when cold
