what is that part calle???
did you ever change your gaskets under there
It's just a paper gasket, nothing special. You can possibly re-use the old one if it's not broken.
Why?
mine broke but i lined it back up and screwed it down. Will this have any effect on my car
IF it's idling okay then you should be fine. If it's leaking air it will idle high....
ps. How did it "break"?? :think:
you're fine. The upper intake (plenum) is very different than the lower intake. Only air that flows through it. An easy way to test for air leaks is to spray some starter fluid around it, and if it sucks any in it will sputter a bit.
yes it ideling ok and no air leaks one day i wil change the gaskets. I wish i would have know when i did my o-ring.
