manitcor Posted January 17, 2006 Report Posted January 17, 2006 IIRC its on the flex plate side. (Inside the block of course). Why does it matter, it wont affect your swap. Everything you wanted to know about swapping a 3400 but were afraid to ask: http://www.3400swap.com/guide_ver_2_5_5.pdf Quote
patgizz Posted January 17, 2006 Report Posted January 17, 2006 believe me, it is worth it! take it from someone who's done a 3400 swap, it so is worth it. 2nd you don't count, the same 3400 was used in both cases Quote
Brian P Posted January 17, 2006 Report Posted January 17, 2006 believe me, it is worth it! take it from someone who's done a 3400 swap, it so is worth it. 2nd you don't count, the same 3400 was used in both cases Quote
THe_DeTAiL3R Posted January 17, 2006 Report Posted January 17, 2006 wouldn't it work just fine to swap the heads and intake? s the block exactly the same????? You can swap the intake and heads from either a 3400 or a newer 3100 (with the BIGGER letters on the plenum). They are the same I beleive. Quote
