f_399 Posted January 16, 2006 Report Share Posted January 16, 2006 Replaced the compressor and recharged the system but its still not working Any ideas? Quote Link to comment Share on other sites More sharing options...
Supreme Cutlass Posted January 16, 2006 Report Share Posted January 16, 2006 what was wrong to start with? Quote Link to comment Share on other sites More sharing options...
f_399 Posted January 16, 2006 Author Report Share Posted January 16, 2006 not getting cold Quote Link to comment Share on other sites More sharing options...
Bossman429 Posted January 17, 2006 Report Share Posted January 17, 2006 Screw you! It's winter here. We won't know what A/C is until March maybe. I would guess that the refrigerant leaked out. If they put dye in the system you can have them look for the leaks, they will glow with the dye. If not, you don't have much of a choice. Have them recharge the system and use dye this time, so they can find the leak when it stops working again. Quote Link to comment Share on other sites More sharing options...
GnatGoSplat Posted January 17, 2006 Report Share Posted January 17, 2006 Did you recharge the system yourself? If so, did you vacuum it first? Do you have a manifold gauge set? If so, what does it read? Quote Link to comment Share on other sites More sharing options...
f_399 Posted January 17, 2006 Author Report Share Posted January 17, 2006 went to a shop to recharge Quote Link to comment Share on other sites More sharing options...
jeremy Posted January 17, 2006 Report Share Posted January 17, 2006 went to a shop to recharge I'd bring it right back to them.......if you paid someone to fix your A/C system and it still isnt' working correctly, then that is their problem and they should have to fix it.... Quote Link to comment Share on other sites More sharing options...
f_399 Posted January 17, 2006 Author Report Share Posted January 17, 2006 replaced the compressor and then went to the shop recharge it Quote Link to comment Share on other sites More sharing options...
GnatGoSplat Posted January 17, 2006 Report Share Posted January 17, 2006 Is the compressor kicking on? Quote Link to comment Share on other sites More sharing options...
jeremy Posted January 19, 2006 Report Share Posted January 19, 2006 Is the compressor kicking on? yeah, does it even kick on at all? Quote Link to comment Share on other sites More sharing options...
f_399 Posted January 19, 2006 Author Report Share Posted January 19, 2006 yeah it does Quote Link to comment Share on other sites More sharing options...
jeremy Posted January 19, 2006 Report Share Posted January 19, 2006 yeah it does does it stay on or immediately click back off? have you taken pressure readings of the system? Quote Link to comment Share on other sites More sharing options...
