Hey all, first off, i'd like to say I'm sorry for asking so many questions.
anyway, i fucked up the cam timing, I didn't rotate the engine prior to setting the front cams. I only realized this when I went to start the car and my airbox caught fire. :shock: My question is if I were to loosen the cam gear bolts, the front two, would the gears freewheel on the cam? The car's a '92 Z34
No they won't. You will have to pull the belt off again and pull the cam gears off to get the lock rings out.
