futuretgper Posted January 16, 2006 Report Posted January 16, 2006 hey is there any difference between 1st w-bodies when it comes too hubs and wheel fitment....how about 1st compared to 2nd gen??? anyone have specs on the 1st gen hub for wheel fitment???? like would wheels from a 96 GP fit on a 90 GP and a 2002 GP forgeting about offset?? im gonna buy custom wheel adapters and i need as much info as i can get!! Quote
terryk2003 Posted January 16, 2006 Report Posted January 16, 2006 i'm pretty sure the bolt pattern is the same...just the difference in offset so you'll need spacers! Quote
Bossman429 Posted January 16, 2006 Report Posted January 16, 2006 Yep, 2nd gen 97+ would need spacers, and with those you should consider longer lug studs to go with, but could probably do without. 96 wheels will fit a 90 no problem, both 1st gen. Quote
futuretgper Posted January 16, 2006 Author Report Posted January 16, 2006 what about the center ring for centering a set of spacers? Quote
z34Phoenix Posted January 17, 2006 Report Posted January 17, 2006 i dont think you will need hub centric rings since your staying with a GM part. as for putting 2nd gen wheels on a 1st gen, they will bolt up, but i know on the 95 monte, that the normal offset will rub the wheel spokes aganst the brake mount bar. CiZiN over at Mymonte.com went thru this, and has the 00+ factory 5 spokes on his 5th gen monte. but had to run a 1/4 spacer in the rear and grind the front brake supporting bar. Quote
GnatGoSplat Posted January 17, 2006 Report Posted January 17, 2006 5x115mm bolt pattern, 70.30mm center bore. Bolt pattern and center bore are the same for 1st and 2nd gen. Quote
