terryk2003 Posted January 13, 2006 Report Posted January 13, 2006 ok...these wheels are advertised for the 2nd gens which i believe may have a different offset!?...the bolt pattern is 5x115 which i'm pretty sure is right...so, will these fit? http://www.3800performance.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=AE-185&Category_Code=WT&Product_Count=3 Quote
DiscoStudd Posted January 13, 2006 Report Posted January 13, 2006 Yep. Those are the exact dimensions of my Eagle 192's which fit perfectly on my Regal. 5 on 115 with a +38mm offset is what you should shoot for (IIRC +42mm is the greatest offset you can fit without rubbing on a 1G dubya body...) Quote
terryk2003 Posted January 13, 2006 Author Report Posted January 13, 2006 sweeeet!!!...what size tires are you running on your regal?... Quote
GnatGoSplat Posted January 13, 2006 Report Posted January 13, 2006 They should fit, those are the exact wheels Davis has on his Cutlass, I think. Quote
DiscoStudd Posted January 13, 2006 Report Posted January 13, 2006 sweeeet!!!...what size tires are you running on your regal?...I'm running a 235/50/17, which is what I figured would give me the least amount of speedometer error when going from my stock size of 205/70/15. I plan on getting 17's for the Impala this year, and will be going with a 245/50/17 tire. The diameter of a 245/50 is virtually identical to the diameter of a 225/60/16 (which the Imp has on there now, and what I'm assuming your car has also.) http://www.paspeedo.com/calculator.htm 225/60/16 = 26.6299 in diameter. 245/50/17 = 26.6457... Quote
terryk2003 Posted January 14, 2006 Author Report Posted January 14, 2006 thanks for that calculator disco!...my car actually has 215/60/16's so it looks like i'd wanna go with 235/50/17 Stock tire diameter is 26.157 inches New tire diameter is 26.251 inches. Quote
Guest TurboSedan Posted January 14, 2006 Report Posted January 14, 2006 another one http://www.miata.net/garage/tirecalc.html Quote
