95 Lumina Stereo Removal
anyone know where i can find a FAQ or writeup on removing the factory stereo out of a 1995 Lumina?
Need to know to help a friend w/ the install of a new deck.
Thanks
Remove the kick panel underneath the dash on the driver's side (4 screws - 2 are plastic) and pull around the perimiter of the dash bezel. Should come right out. The bezel is a bit difficult to manuver around the steering column though, so it helps to loosen the 2 bolts holding the column in place so you can drop it down an inch or so.
The stereo is held in place by 2 screws.
