Fiberglass 3" cowl for 89-96 Cutlass Supremes!
  • Replies 50
  • Created
  • Last Reply
Top Posters In This Topic
  • jeremy
    10
  • 2CUTTYS
    7
  • 94CutlassXtreme
    7
  • Prospeeder
    5
I like the hood reductors!
part number? what year gtp???
as for the gear shift..... uhhh.... WTF?
The shifter on that car was the hurst lightning rods from the 80's style Hurst/Olds cars... That car is kinda a joke.
i never really understood that car....or why someone would want lightning shifters in a w-body :shrug:
i personally mite be buyin it
that should look nice on an otherwise stock sedan
ya i duno i think it would look good i also was lookin into gettin like jus the fiberglass cowl and gettin it bonded on but i dont feel like cuttin my hood up..id rather have the stock 1 and then a cowl 1
what exactly do the shifters like that even do?
They supposedly make it easier and "Faster"- "Lightning fast" to shift the old 3 speed autos, the lever closest to the driver lets you do drive, reverse, neutral, or 3rd geari believe, the second allows you to go to second gear, and the third or farthest away allows you to go to first gear
ok i found out the part number and cost . drivers side 88894521 pass 88894520 cost 195.59 per side
i checked KARLS chevy here where i live and found them cheaper here
2001 NW 13th St.
Gainesville, FL 32609
gmparts@gmotors.com
Phone 352-378-5301
Fax 352-378-1880
i ordered mine today
jeremy, just because they are cool. GM did have plans for the cutlass 442 but decided not too.
Those lightning rod shifters are made by hurst. badassoldspower was right about how they work. they won't work in a 4T60-E or any other electrically controlled automatic. all they do is allow manual manipulation of the valve body. I'd put them in mine if I could. it's not so much of puttin' em in a W. I'd like to do it because it plays up on Oldsmobiles history.
Isnt that kind of the same thing as the "1" "2" "3" where you can kinda half-assed control what gear you wanna use/what gear your in?
94CutlassXtreme they won't work in a 4T60-E or any other electrically controlled automatic
YES it will to work on that tranny . Who told you they dont work
ere is the option codes for this 1994 Oldsmobile Hurst Olds:
VIN#1G3WT35X6RD384574
Build Date: April 7,1994
Build Plant: 1RDW-Doraville assembly plant, Georgia
AC3-SLIDING FRT DR,LH
AL4-BKT
A31-POWER OPERATED,ALL DOORS
BYP-SPORT EQUIPMENT PKG.
B35-REAR CARPETED FLOOR MATS
B71-COLORED
C67-AIR CONDITIONING
DH6-MIRRORS-VISOR,ILLUMINATED INCL
DOE-DORAVILLE,GA,USA
D81-RR-AERO WING
FE9-FEDERAL EMISSIONS
IK2-INTERIOR DESIGN (K2)
K34-CRUISE CONTROL
LQ1-GAS,6 CYL,3.4L,MFI,V6,HO,
M13-4T60-E AUTO ELECTRIC TRANS
NC5-DUAL VERTICAL TAIL PIPES,CHROME
PY0-16X6.5, ALUMINUM
R7A-SALES ITEM NO. 26
T86-BACKUP PAINTED
T96-FOG,FRT
AJ3-INFLATABLE,DRIVER
AN3-CLOTH FRONT BUCKETS
AU0-REMOTE ENTRY
A90-LID-RE CONT ELEC RELEASE
B34-FLOOR MATS, CARPETED INSERT
B57-EXTR,DELUXE
B84-EXTERIOR
DG7-DR/PASS REMOTE ELEC
DL5-ROADSIDE SERVICE INFORMATION
D55-FRT COMPT,FLOOR
FE3-TOURING AND LOAD LEVELING
FW9-TRANSAXEL FINAL RATIO 3:43
JL9-ANTILOCK
K68-GENERATOR
MX0-4 SPEED AUOTMATIC TRANSMISSION
NA5-EMISSION SYSTEM,FEDERAL TIER 0
NX4-SPORT LEATHER
QXJ
R9Z-SALES ITEM #100
T93-TAIL & STOP SPECIAL
UB3-I ST,OIL,COOL TEMP,VOLTS,TR
US7-POWER ANTENNA
UM6-RADIO-AM/FM STEREO WITH
U66- 7,CUSTOM
VB7-FRT & RR, SPORT
VK3-FRT MOUNTING PACKAGE
WJ7 -INTERIOR*LEATHER*( TO BE USED )
VM3- CONSUMER,CONTAINS BPR IMP STAN
1SB-PERFERRED EQUIP.GROUP-1SB**
16U-BRIHT WHITE
16T-BRIGHT WHITE (94)
VH9-OWNER INFO MAN
V73-USA/CANADA
Z7S-OLDSMOBILE CUTLASS SUPREME CONV
1SZ-OPTION PACKAGE
79I-RUBY RED (96)
SVO-HURST/OLDS W30 APPEARANCE PKG
There was never an actuall 94 Hurst/Olds. The guy who put that car together made it that way, and he added his own option code on the end of the RPO code list. That list is from his cardomain page. That car is just a regular DOHC cutlass with alot of visual upgrades to make it seem like it was a factory special edition. Valenti is the guy who made it. The OSV emblems are just a copy of the ones used on the Olds Alero/Intrigue OSV concepts.
x2
yep thats why its called a concept but the shifter will work in a 94 cutlass with electic auto trans
yep thats true.its a concept, but thats not the point. he said the shifter wouldnt work in any or the cars with it shifter will to work in a 94 with electronic trans 4T60-E. ll i should was the tranny that was in it. yes its a concept i know that
I don't know, I don't see how it could. On trannys like the 440T4 and the 4T60, upshift points are primarily deicded by the throttle pressure cable, governor, etc... The 4T60-E has no governor or TV cable system. The shift points are determined by input from various sensors, and fluid direction in the valve body is controlled by 4 solenoids. How can you mechanically control an electronically controlled automatic?? That Cutlass with the shifters might have a 4T60. If the production date is in 1993, chances are, thats what it came with. Hell, maybe two of the shifters in that car are primarily for show.
3in cowl for a cutty? My camaro is a 2in cowl. What is under there that will pop out from under the hood? :?
What will pop out?! All that raw power from the 2.8
