Cueman Posted January 8, 2006 Report Posted January 8, 2006 Just replace the thermostat, now both fans are not working. I drove the car so the engine was hot, and had the A/C on max. Neither fans came on, even though the temp was at the 2nd hash mark (right before the red) This is opn a 95 cutlass.. How can I test the fans? Is it posibly the CTS? Any help is appreciated! Brian Quote
Regal_GS_1989 Posted January 8, 2006 Report Posted January 8, 2006 Did you properly bleed the cooling system first?? Quote
Cueman Posted January 8, 2006 Author Report Posted January 8, 2006 Yes, I opened the bleeder screw on the thermostat. Had to do it 4, of 5 times until coolant came out. I know that our cars run hot when idling, but the fans never come on. Should I bleed it more? Quote
Regal_GS_1989 Posted January 8, 2006 Report Posted January 8, 2006 If the system is bled properly, the car should run at the normal temperature while driving down the highway. I have my fan set up so that is comes on when you turn the key on, and mine always runs at about 180*. Idleing or driving down the highway. Hot Summer day or Deep freeze of winter, It is always at 180*. I would try bleeding it some more, and try using the screw by the water pump too. Also, when the temp guage was reading that high, was there any heat?? Quote
