I recently acquired a DIC (Trip Computer) from a 95 GP, which was working. I plugged it into the harness but it doesn't work. Fuses #10 & #15 are OK. The lights on the left do light up (the little red dot indicators, all at once, and stay on), and the lighting works with the dash dimmer, but no readouts or display. Pressing the buttons do nothing. Can anyone tell me if there is an additional item that may need to be either plugged in or activated to make it work or if there is something else I may have overlooked?
Also, I ordered the temp sensor from the dealer today, and need to know where the harness to plug that into is located. I've seen blurbs stating passenger side behind grille, but I see nothing.
All plugs are behind dsh for HUD (which I also installed) and the control switch for the HUD (which I also installed), and that all works, so I don't think the circuit is inoperative. There has to be something I'm missing.
Thanks
Guest Anonymous
Is it the 3100? If it is the temp. sensor should be below the throttle body in the lower intake.
