Guest Anonymous Posted January 7, 2006 Report Share Posted January 7, 2006 I'm looking into getting this rearview mirror: Its from a late 90's early 2000's yukon/silverado/ GM vehicle. Despite the airbag warning, will it work in my car with the needed sensors? How does it mount? Quote Link to comment Share on other sites More sharing options...
jeremy Posted January 7, 2006 Report Share Posted January 7, 2006 it looks like the mount is partially visible in the 2nd picture, just to the left of the edge of the paper...you probably have to glue the one piece on and have the mirror slide over it, just like most every other rearview mirror Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 7, 2006 Report Share Posted January 7, 2006 so they dont just "pop" into place? Quote Link to comment Share on other sites More sharing options...
Cam'ron Posted January 7, 2006 Report Share Posted January 7, 2006 no unless it happens to fit on an existing mirror mount on your windshield Quote Link to comment Share on other sites More sharing options...
DiscoStudd Posted January 7, 2006 Report Share Posted January 7, 2006 GM uses a standard windshield "slug" for all of their vehicles, and that one looks the same as all of the other GM's. What's the worst that can happen, anyway? If it doesn't fit over your car's slug, just scrape yours off and glue the one from that mirror on your windscreen... Quote Link to comment Share on other sites More sharing options...
Crazy K Posted January 7, 2006 Report Share Posted January 7, 2006 if you use search you will find a few topics on these type of mirrors. type: mirror and dimming I just got one from a 99ish aurora, no map lights, and it has three wires it is gentex "gntx" on back black -ground pink -hot switchable (so mirror works only when car on!) lt green - hooks to reverse power circuit It will work... Does it have maplights? Is it gentex, and not donnelly? Donnelly's fail alot. I think Gm uses gentex only.... in my experience, btw. Quote Link to comment Share on other sites More sharing options...
GOT2B GM Posted January 7, 2006 Report Share Posted January 7, 2006 I have a Donnelly auto dimming mirror with maplights out of a 98 Regal GS wired up in my 93 Z34 and it works fine. Quote Link to comment Share on other sites More sharing options...
Crazy K Posted January 7, 2006 Report Share Posted January 7, 2006 Donnelly's work, but they often leak. (the polarizing fluid) Quote Link to comment Share on other sites More sharing options...
Brian P Posted January 8, 2006 Report Share Posted January 8, 2006 windscreen? Quote Link to comment Share on other sites More sharing options...
digitaloutsider Posted January 8, 2006 Report Share Posted January 8, 2006 Sean has that exact mirror in his Regal. Quote Link to comment Share on other sites More sharing options...
john99gtp Posted January 8, 2006 Report Share Posted January 8, 2006 Sean has that exact mirror in his Regal. and ive been begging him to get me one Quote Link to comment Share on other sites More sharing options...
GnatGoSplat Posted January 9, 2006 Report Share Posted January 9, 2006 That's an 03+ mirror. 00-02 compass/temp mirrors are similar, but don't have the airbag indicator and have a simpler 7-pin connector. They are easy to install, I put one in my truck which had the base model mirror. Quote Link to comment Share on other sites More sharing options...
