92chevyeuro Posted January 3, 2006 Report Posted January 3, 2006 My abs has been giving me some trouble. Everytime i put on the brakes to come to a stop, my abs kicks in. How do i unhook the abs altogether until i can get it looked at? Quote
Supreme Cutlass Posted January 3, 2006 Report Posted January 3, 2006 The ABS unit is under the passenger seat. Quote
1990lumina Posted January 3, 2006 Report Posted January 3, 2006 Can you not just pull the ABS fuse? Quote
Prospeeder Posted January 4, 2006 Report Posted January 4, 2006 mabye get it fixed, but you can just pull the fuse, but it will throw an ABS light, wich you might wanna pull out the buld if ur gonna do that Quote
Crazy K Posted January 4, 2006 Report Posted January 4, 2006 \ said: The ABS unit is under the passenger seat. abs computer? Not in a car w/o PMIII. A 92 lumina EBCM is hidden in the front drivers side fenderwell towards it's rear. ANd same location on all gen 1 cars with vacuum assist brakes with ABS. You can stop it by pulling the abs fuse. but it will turn the light on. The probelm you are experiencing is called phantom ABS. If you can isolate which wheel is doing it, the senosr may just need cleaning or replacement. Quote
92chevyeuro Posted January 5, 2006 Author Report Posted January 5, 2006 I believe its the front passenger wheel thats doing it. I was just going to disconnect it untill i can get it looked at because i know it needs to be fixed for inspection. Quote
White93z34 Posted January 5, 2006 Report Posted January 5, 2006 till you get that sensor replaced just pull the 10a fuse in the glovebox. Quote
92chevyeuro Posted January 8, 2006 Author Report Posted January 8, 2006 ill have to check, i didnt know there were fuses in the glovebox. Quote
