Guest Anonymous Posted January 2, 2006 Report Posted January 2, 2006 I'm looking for an alternative to my antenna. I don't like that stupid tall mast sticking up... I also don't want the power antenna, as I find them to break easy. Does anyone know if they make any sort of thing that replaces the tall mast and is just like some sort of flat piece that goes where the antenna once was but still picks up the frequencies? Quote
1990lumina Posted January 2, 2006 Report Posted January 2, 2006 I dunno about that, because the element should be in contact with the radio waves, and a shorter/no element wouldn't pick up stations as good as what you have now. That being said, if you wanted to go real expensive you could replace the rear window with an antenna already built into it (like my mom's CL), or maybe there is something you can buy aftermarket that fits in the rear window.. I know when I first got my car I took the antenna off the car, and glued a piece of rubber over the stud, it worked fine while sitting, but when drivng the local stations would fade in and out. Maybe you could just buy a smaller rubberide antenna like I use to have. They aren't nearly as high. I'll find a picture for you, but over time they bend from wind resistence and look like you've just done 100mph when the car is standing still lol) Or you could also just the cut the antenna mask you have now to a short size, but on the end you'd have to put something on it so it isn't sharp. Between the metal and rubber antennas I noticed very little difference in signal reception - I went out of town with the rubber one and had no problems. I only put the mteal one back on because the rubber one belongs to my RX-7 Rubber antenna: With metal antenna, much longer Quote
terryk2003 Posted January 2, 2006 Report Posted January 2, 2006 http://www.pfyc.com/store/merchant.mv?Screen=PROD&Store_Code=PFYC&Product_Code=GN1013&Product_Count=23&Category_Code=MCEXT something like that?...i want one of those for my cutlass... Quote
Guest Anonymous Posted January 2, 2006 Report Posted January 2, 2006 Ive seen some of the shorter ones on ebay. I think I will end up going for one of them, its probably the best i will get. Quote
jeremy Posted January 5, 2006 Report Posted January 5, 2006 just "shave" the antenna, so you have functionality but you don't have the ugly external antenna......I have done it on a Probe and a Fiero, it should be pretty easy to do on a w-body too... Quote
Guest Anonymous Posted January 5, 2006 Report Posted January 5, 2006 how was the sound quality/reception? what exactly did you do? Quote
White93z34 Posted January 5, 2006 Report Posted January 5, 2006 i'd consider another power antenna, just remember to unplug the power source with it raised in the winter so it dosen't get destroyed. you should get alota life out of one that way. Quote
jeremy Posted January 6, 2006 Report Posted January 6, 2006 how was the sound quality/reception? what exactly did you do? The sound quality/reception was virtually unchanged....for the Probe, I shaved it on the outside and put the factory antenna along the rear quarter panel behind the plastic hatch pieces (pics below) Here is a pic of the Fiero antenna mounted behind the front quarter panel... Quote
Darksyde Posted January 7, 2006 Report Posted January 7, 2006 Could also by the stick on antenna's for the bottom of your windshield. Pretty much not noticable at all Quote
PeNZ Posted January 8, 2006 Report Posted January 8, 2006 i'd consider another power antenna, just remember to unplug the power source with it raised in the winter so it dosen't get destroyed. you should get alota life out of one that way. Thats what happened to mine, the ice burnt out the motor. Quote
