headlight out
the left side of my 92 regal went out the bulb is ok and changed but it still not working what could it be?
thanks mike
Is the right side still working??
Does your Regal have seperate low and high beams?? If so try switching your signal stalk to high beams and see if both sides work...might have a wiring problem in the low beam side or something.
Try cleaning the connection at the low beams and then putting some dielectric grease in the connection and plug it back in.
prolly not a fuse if the other side works...i would check the plug and make sure none of the wires are broke off and make sure its not all corroded!
Hmm, sounds like you will find a damaged connector/corrdoed connector on your left low bulb then. Good luck :D!
