M-I-A Posted December 29, 2005 Report Posted December 29, 2005 Hey guys. I bought some GM TEC and I want to use it on my car. I know you cant pour it in our side ways TB. I have heard that you can use a VAC line to do it with. Ok heres my question, On my engine which and were is the VAC line I have to use? Thanks Quote
GP1138 Posted December 29, 2005 Report Posted December 29, 2005 There should be a vacuum line on the brake booster you can pour it in. I like to stick a funnel into it and just pour it in. Pull it downwards and it'll just pop off. Quote
M-I-A Posted December 29, 2005 Author Report Posted December 29, 2005 Is it one of these? Thanks Quote
GP1138 Posted December 29, 2005 Report Posted December 29, 2005 No, it's near the brake fluid reservoir. Quote
ToroToro Posted December 29, 2005 Report Posted December 29, 2005 The number "2" you circled in the first pic is the vaccum line that comes from the brake booster, and you can use it. It's a fuck of a lot easier to take the line off from the booster than it is to get it off the manifold though. Mine was really stuck. Quote
Crazy K Posted December 29, 2005 Report Posted December 29, 2005 The number "2" you circled in the first pic is the vaccum line that comes from the brake booster, and you can use it. It's a fuck of a lot easier to take the line off from the booster than it is to get it off the manifold though. Mine was really stuck. x2 take it off from the vacuum booster side, pull it up (if you are careful you can turn the entire tube), so that it also has a bit of help from gravity. Then ram a funnel into it and pour..... Quote
M-I-A Posted January 1, 2006 Author Report Posted January 1, 2006 When the cars running and I disconnect that line the car shuts off. So I had to keep my thumb over half the line while pouring the TEC in there. Same for you guys? How much do you usually pour at a time also? Thanks for the help guys. Quote
Supreme Cutlass Posted January 1, 2006 Report Posted January 1, 2006 When the cars running and I disconnect that line the car shuts off. So I had to keep my thumb over half the line while pouring the TEC in there. Same for you guys?How much do you usually pour at a time also? Thanks for the help guys. Pull it off a little by little, then it'll only stumble. Quote
GutlessSupreme Posted January 1, 2006 Report Posted January 1, 2006 if you're using the brake booster line make sure you squeeze it partially shut anyway, otherwise it'll suck up the whole bottle in two seconds. you don't want that. if you suddenly grow a third arm, use it to keep the throttle butterfly open a bit. just keep reving it a little (not wide open). it'll keep running. if it doesn't just restart it. Quote
