3.4 DOHC spark plug connectors
I need some connectors for the 3.4L spark plugs. They have a different design that is longer and has a larger diameter neck to prevent it from being pushed back up into the boot. I need new wires, but will have to cut them to custom length and need the connector end that attaches to the plug itself.
Is it possible to go larger than 7mm? Going through the boot it is pretty tight with the 7's in there and I would like to go larger. Anybody know a website or supplier that could help me out?
the problem is I relocated my coil packs and I will have to have some custom lengths. I can easily get some wire and run it through the boots that I already have. The main problem is the connector end that goes to the plug.
a buncha people have done coil relocation, just see how they run their wires.
good idea!
