egr valve help
ok i have 90 lumina ... i did intake gaskets upper and lower ...well the egr valve wont tighten up, i belive i striped the bolt hole..so now it wont tighten ...the car is running bad now....could that be the problem ??anybody else have anything else simlar happen to the them? i am going to the yard friday to get a upper intake for it ! but any help would be nice thanks [/b]
I have not stripped out an intake before, but they are weak metal so it could be that.
pull it and look, you'll be able 2 see if its stripped out or not, also check the bolts, see if they are in good shape as well.
Bolt hole? Shouldn't it have studs?
I thought they were all studded into the plenum, except for 1 out of 3 on the digital EGR ('92+) which was a bolt.
