intern8tion9l Posted December 29, 2005 Report Share Posted December 29, 2005 alright i have 2 questions for you tgp regulars. 1: are the little metal bands found around the lower hose connector supposed to be on the upper one? the one that is kind of an angle up to the upper pipe. 2: are the hard pipes aluminum or steel? i want to get a bov and need to know what material flange to get. thanks for any help Quote Link to comment Share on other sites More sharing options...
Garrett Powered Posted December 29, 2005 Report Share Posted December 29, 2005 they are steel Quote Link to comment Share on other sites More sharing options...
Prospeeder Posted December 29, 2005 Report Share Posted December 29, 2005 yea, definatly steel, and yes the upper ripple coupling has the little metal hoops, wich i wonder what there doing on the outside, it would make more sense for them to be on the inside to prevent colapsing, not the ouside Quote Link to comment Share on other sites More sharing options...
GutlessSupreme Posted December 29, 2005 Report Share Posted December 29, 2005 yea, definatly steel, and yes the upper ripple coupling has the little metal hoops, wich i wonder what there doing on the outside, it would make more sense for them to be on the inside to prevent colapsing, not the ouside How exactly would they collaspe if they have 10 PSI of air being pressed against them from the inside out? Quote Link to comment Share on other sites More sharing options...
Prospeeder Posted December 29, 2005 Report Share Posted December 29, 2005 OH nm that was a stupid thing i said, nm, i was soo thinking of the One from the airbox to the turbo, but the upper ripple coupling does have the rings Quote Link to comment Share on other sites More sharing options...
Guest TurboSedan Posted December 29, 2005 Report Share Posted December 29, 2005 yea, definatly steel, and yes the upper ripple coupling has the little metal hoops, wich i wonder what there doing on the outside, it would make more sense for them to be on the inside to prevent colapsing, not the ouside How exactly would they collaspe if they have 10 PSI of air being pressed against them from the inside out? i think they are there to help prevent the hose from ballooning out, which could pull the hose off the pipes or intercooler end tanks. Quote Link to comment Share on other sites More sharing options...
intern8tion9l Posted December 30, 2005 Author Report Share Posted December 30, 2005 yeah they seem to be fairly cheesy to be going through that kind of abuse with boost and all. guess i'll have to imrovise, cause my upper one lacks the metal bands. thanks guys Quote Link to comment Share on other sites More sharing options...
GutlessSupreme Posted December 30, 2005 Report Share Posted December 30, 2005 yea, definatly steel, and yes the upper ripple coupling has the little metal hoops, wich i wonder what there doing on the outside, it would make more sense for them to be on the inside to prevent colapsing, not the ouside How exactly would they collaspe if they have 10 PSI of air being pressed against them from the inside out? i think they are there to help prevent the hose from ballooning out, which could pull the hose off the pipes or intercooler end tanks. I know that, that's why I was asking why they'd collaspe Quote Link to comment Share on other sites More sharing options...
