ExZion Posted December 28, 2005 Report Posted December 28, 2005 Me and friend have been looking at my 1994 Cutlass Supreme sl 3.1L We were wondering how hard it would be to pull that engine and trans and replace it with a 3800 Supercharged out of a Pontiac SSE. Would It be worth it? Quote
terryk2003 Posted December 28, 2005 Report Posted December 28, 2005 check out http://www.l67swap.com ! and FWIW: if the bonneville is supercharged it would be an SSEI! Quote
Guest TurboSedan Posted December 28, 2005 Report Posted December 28, 2005 and FWIW: if the bonneville is supercharged it would be an SSEI! not necesarrily. the SSE, (probably SLE too) and even the SE could get an L67 depending on year. i have seen an L67 Bonneville SE in person, but it was a '93 IIRC. Quote
stockgp Posted December 28, 2005 Report Posted December 28, 2005 i think the motor mounts are different from w bodies, aren't they? Quote
mfewtrail Posted December 28, 2005 Report Posted December 28, 2005 i think the motor mounts are different from w bodies, aren't they? Not sure about the motor mounts, but I'm almost certain that various other brackets need to be changed out if you're getting an engine from a Bonneville. Quote
ExZion Posted December 28, 2005 Author Report Posted December 28, 2005 ok thanks for the input guys what motor would you recomend? Quote
manitcor Posted December 28, 2005 Report Posted December 28, 2005 you can get it from a bonnie, you just need to change out the motor mounts. Word of warning, you cant just swap the engine. You will need: Engine (complete with injectors and accessories) Transmission Engine Wiring Harness Computer Most likely a new fuel pump Axels Its alot of work but it is a good swap. If your not looking to spend that much time and money a 3400 is a direct drop in with your exisitng transmission and computer. And will be good for 15-20hp over what your running with your 3100. Costs the same as replacing the 3100 as well. Quote
brianteel Posted December 28, 2005 Report Posted December 28, 2005 get a GTP motor and parts. it will save alot of time and money that way. also try to find a 98 or 99 monte or lumina 3800 harness Quote
brianteel Posted December 29, 2005 Report Posted December 29, 2005 Parts & Components Needed: 1. L67 Series II Supercharged Engine (VIN “1â€Â) 2. 4T65E – HD Transmission 3. 4T65E – HD Transmission Lines 4. 4T65E – HD Transmission Axles (shorted axles are recommended) 5. L67 Powertrain Control Module (PCM/Computer) Custom DHP recommended ** 6. L67 High-Pressure Power Steering Line 7. L36 Monte Carlo or Lumina harness (98-99)* 8. L67 Cruise Control Module & Cable (Optional) 9. L67 Stock or Custom/Aftermarket 97+ Style Exhaust Downpipe 10. L67 Coolant Hoses (New) 11. Walbro High-Pressure Fuel Pump 255 ltr/hr or greater (stock pump will work of low HP appilcations) * Items can be assembled as kits offered at the L67Swap Store ** DHP Custom Programming for L67swapped cars. Revised by brianteel http://www.l67swap.com/forum/cms_articles.php?cid=19 Quote
