I need a pic of the SC belt routing for a 98 GTP........ASAP
Thanks.....it was for a coworker...his 98 GTP threw the SC belt. The SC tensioner pulley froze on him. He was wondering how to get it back on. Thanks.
We now just realized the diagram is under the hood...but completely covered in dust....he doesn't exactly take good care of it.
he was driving around without the SC workin...i was amazed the car even had some get-up with the SC blocking the intake.
When my friend's dad still had his Bonneville w/ L67 he used to replace that belt A LOT!
Get up with the s/c belt off? :lol:
My ole 3100 could probably take the gtp with the belt off haha.
the superchargers all have a "bypass" in them, so they won't restrict the airflow if they are disabled - the car should still run, fairly well too.
--Dave.
--Dave.
i'd love to know how that bypass works, because from looking at the underside of a m90 i can say i don't see how much air could get in without it spinning.
--Dave.
Um no. Without the s/c spinning it restricts the shit out of the air intake. Makes it slow as crap too.
Thanks for the help guys.
and ya, isn't that sc a big restriction.....and also the low compression of the L67 would take away from the power of a NA 3800..right?
yes, the compression is lowered on the l67 but is higher on the l36 this is mainly because the 90V block is very knock prone. You can put an L67 topend on an L36 with the right tuning. When done you will actually be faster than an L67 with the same size pulley due to your higher compression ratio.
