f_399 Posted December 26, 2005 Report Posted December 26, 2005 my AC stop working it got hot today and decided to use it.... turned it on, heard the compressor make an unusual sound, it got cool for a while then when my revs got higher it turned off now it just wont work. i guess its not so bad now that its winter but i do want to get it fixed. how much? whats the worst case scenario? Quote
DaveFromColorado Posted December 26, 2005 Report Posted December 26, 2005 sounds like some of the refrigerant (R134a) leaked out and the pressure is just a bit too low to allow the compressor to activate . I'd check your pressures and go from there. --Dave. Quote
fastbird232 Posted December 26, 2005 Report Posted December 26, 2005 Get one of those repair/refill kits. It has some additive in the refrigerant that reconditions the seals and whatnot. Quote
3pt1lumina Posted December 26, 2005 Report Posted December 26, 2005 Jeez it's 21*F outside today you don't need A/C!!! I agree, sounds like your refridgerant leaked out. Get one of those kits ( I think they're like $20) and recharge it. You need to do it on the port next to the battery I believe. Which means the airbox has to come out (If I'm not correct, someone please correct me) Since you have a 97, R134-A is going to be your friend. 8) Quote
f_399 Posted December 27, 2005 Author Report Posted December 27, 2005 i just added refrigirant 2 months ago.... Quote
3pt1lumina Posted December 27, 2005 Report Posted December 27, 2005 hmm... Okay 2 things. Either you have a major leak or the compressor or condenser died. Typically if you lose all the refrigerant the compressor will stop kicking on. When you charged it 2 months ago, did you put the oil in with the refrigerant for the compressor? If it were me, I'd test how much refrigerant is in the system and if it is pretty full, I'd bet the compressor took a dump on you. Quote
DiscoStudd Posted December 27, 2005 Report Posted December 27, 2005 Take the airbox out, remove the cover on the low-pressure port, and depress the schrader valve. If no refrigerant releases when you depress the valve, then it's a safe bet that your system's empty... Quote
f_399 Posted December 27, 2005 Author Report Posted December 27, 2005 since its not too hto should i wait till after winter to have it checked? i have no idea what i am doing so i will have to go to a shop to have it checked Quote
DaveFromColorado Posted December 28, 2005 Report Posted December 28, 2005 I'd get one of those cheap kits with the UV dye in it, and top it off with that again (assuming the stuff leaked out) that way when you go to the shop to have them look at it, they will be able to look for the leaks with the UV light. --Dave. Quote
Whiskey River Posted December 28, 2005 Report Posted December 28, 2005 If you have a leak, unless it is a tiny pinhole leak in the evaporator, then the stop leak stuff will do no good. You could also have an over pressure situation. Without pressure readings, everything is merely speculation. If you can borrow or rent a set of gauges, give me pressure readings and the ambient air temperature and then we can start diagnosing the problem. Quote
