GnatGoSplat Posted March 16, 2003 Report Posted March 16, 2003 Penny loves to play with my DIC! Driver Info Computer, that is. I put an '88-91 DIC in Penny's 94 convertible. It's pretty cool, because I think I have the only 94 Cutty with a DIC. Unfortunately, I discovered NOT everything works. GAUGES, trip computer functions, SPEED functions, Oil life monitor, that all works. Anything to do with FUEL (INST ECON, AVG ECON, Gallons used, etc.) does NOT work. I guess there is just no fuel data on the ALDL in a 94. When I put it in INST ECON, it says 0.0 MPG when the car is stopped, and 80.0 MPG when the car is moving. There's no in-between. One of these days I'll see if I can figure out what needs to be done to the MEMCAL to make it spit out fuel data on the ALDL. Until then, what features it offers is pretty cool anyway. Quote
NORBI Posted March 16, 2003 Report Posted March 16, 2003 Back in the days (last year) i was thinking about putting a DIC in my Convertible but never got it because i had to get rid of the car before it god a HUD and DIC Quote
crc Posted March 16, 2003 Report Posted March 16, 2003 Not sure if you want to go to the trouble of hooking up the Fuel Eco readings, they're not very accurate and can be outright useless most of the time (this is with ECM upgrade).. I like all the other features though, like oil change meter, battery voltage, and coolant temp. Quote
ismellrealbad Posted March 16, 2003 Report Posted March 16, 2003 damnit i want one for my friggin grand prix.......they are like trying to find gold!!!! Quote
Guest TurboSedan Posted March 16, 2003 Report Posted March 16, 2003 dang, i got one sitting in my room waiting to go in, i'm just too lazy to install it. that and the ACC.... joshua Quote
brian89gp Posted March 16, 2003 Report Posted March 16, 2003 Its not that the 94 doesn't have the same data in the ALDL, but it was re-arranged a great deal. Quote
GnatGoSplat Posted March 16, 2003 Author Report Posted March 16, 2003 Its not that the 94 doesn't have the same data in the ALDL, but it was re-arranged a great deal. Hmmmm, tell me what you know! Quote
brian89gp Posted March 17, 2003 Report Posted March 17, 2003 Just that. I was messing with EFI Live V4 one time and it could not figure out the 94 ALDL datastream. All the other code masks use a similar datastream with the same timing, but in 94 they completely overhauled it. I was talking with someone and they said that the ecm is not OBDI, and not OBDII, its inbetween (OBDII SES codes non-the-less). Also if you look at the binary files of the 94 DOHC chip compared to all others, not a single table is relitively close to what the others are. They re-wrote the entire chip. Quote
GnatGoSplat Posted March 17, 2003 Author Report Posted March 17, 2003 Yeah, it's a weird hybrid PCM for sure. It has the same casing, connectors, and even diagnostic connector as the OBD I, but the pinouts of the PCM itself are different. At least most of the chatter data seems to be the same... Do you know anything about the chatter data? As this is what the DIC monitors (the DIC actually just goes into "DIAGNOSTIC MODE" when the ECM is asked to broadcast diagnostic data on the ALDL). Quote
brian89gp Posted March 17, 2003 Report Posted March 17, 2003 Yea, I know about chatter data (ie ALDL datastream) but not on the 94. As far as i care the 94 ecm can rot in hell, I'm droping in a 91-93 DOHC ecm which is more easily messed with, and all I loose is SFI. Even trade I think. Quote
GnatGoSplat Posted March 17, 2003 Author Report Posted March 17, 2003 Don't forget MAF! Isn't MAF usually more forgiving of mods though? I thought most MAF cars you can just install larger injectors and it'll work, while speed density pretty much requires modifying the cal data. Do you know where I can find a BIN from a 94? Quote
