odd electrical cut out.
monday, when it was like 0(give or take a couple of degrees) i was on the way to work, and when i needed to brake, the radio, gauges, and headlights cut out. came back on after i let off the brake. it only happened once more and it appears to have gone away. :? i should check the aux post nut, but its too cold out. i'm also thinking since the battery is seeping a little, maybe come acidic corrosion crap might be on a wire or 2. i'll get to it when i can get in a garage.
only time mine did that was when the alt went out the first time.
Ditto. Mine was feeding the proper voltage, but at about 1/8 the proper amps.
Check, clean and tighten all major electircal connections and see what happens. If you're lucky could just ba a little corrosion on a battery terminal or something.
its most likely the battery, in it's third year of usage. should last till after christmas........i hope! :shock:
