Pabz Posted December 20, 2005 Report Posted December 20, 2005 Getting the plans set to do the upgrades for the recently procured cutlass I can get a real deal on some napa parts so i just wanted more info on these parts. I want some good stuff but i don't want to buy anything unnecessary. Prices are listed from napa site, still waiting on prices i could get them for. First off, Parts for the 96+ front knuckle hub assembly ----- New Ball Joints MRC 104163 $19.49 (these the cheapos??) NCP 2601331 $56.49 ------- Strut bearings NCP 2613137 $42.49 or strut bearing plate w/bearing $66.99 NCP 2613447 they list strut bearing plate insulator w/ bearing for: standard suspension NCP 2613230 $63.99 heavy duty suspension NCP 2613231 $59.99 whats the diff for, and which should i go with standard or heavy duty? ---------- Brakes - Front ROTORS 11.25" TS4886454 $22.49 (cheapos??) UP86549 $78.99 (noise dampening iron???) UP PR 86549L $119.00 (slotted rotors :shock: ) UP PR 86549R $119.00 PADS I am using Ceramix pads on the 89 & 97 regal and they last a long time!!! UP CMX 7265 $77.99 Rears CALIPERS (most likely gonna get junked ones) Anyone know the difference in quality between these. UP 4422206M (&7M) $144.00 each comes with hardware & pads TS1422206M (&7M) $114 each, comes with hardware & pads maybe braket too SDC 2422206 $99 each, comes with hardware & no pads each on has $88 core charge, (think they'll notice if i gave them 90 cores??) PADS UPCMX7387 $72.99 Quote
Pabz Posted December 21, 2005 Author Report Posted December 21, 2005 Nobody cares :bawl: Jeez Pabz your so stupid My main concerns are, are the cheapos that bad? what is "noise dampening iron"? Heavy duty or standard, why the difference? is heavy duty better or worse? Quote
pwmin Posted December 21, 2005 Report Posted December 21, 2005 i dont know much about napa parts. advance and carquest i do. sorry Quote
slick Posted December 21, 2005 Report Posted December 21, 2005 The cheapo pads and rotors suck. I used them the last time I did my front brakes(was short on cash), and it's only been 5-6 months, and I have noticed significant wear. "Noise dampening iron" is probably kinda like the anti-squeal that you would put on the back of your pads before placing them on the rotors so they don't squeal when you brake. Heavy duty is probably for extreme conditons, like heavy stop and go traffic, or autocrossing. Something that requires using your brakes harder often. Quote
Pabz Posted December 21, 2005 Author Report Posted December 21, 2005 OK thanks for the reply on the cheapos, but let me put the other questions in better context what is "noise dampening iron"? (this is refering to the rotors, not pads) What metals are rotors made out of? maybe the center part is iron?? Heavy duty or standard, why the difference? (this refers to the suspension insulators and bearings.) is heavy duty better or worse? Quote
slick Posted December 21, 2005 Report Posted December 21, 2005 Hmm... good question on the rotors. Not sure on the material they are made from, but maybe it's some sort of marketing scheme?? As for the suspension stuff, the heavy duty stuff should actually be made of better material and last longer. They will suffer less from wear and tear. Quote
Pabz Posted December 21, 2005 Author Report Posted December 21, 2005 As for the suspension stuff, the heavy duty stuff should actually be made of better material and last longer. They will suffer less from wear and tear. Ya, i was thinking the same. Can anyone prove this hypothesis wrong? Quote
pwmin Posted December 21, 2005 Report Posted December 21, 2005 dont pay that much for rotors. go somewhere else. and for a cheaper price, i would def go with the hd's. it may ride a little rougher but they should be stronger and last longer hth Quote
PeNZ Posted December 21, 2005 Report Posted December 21, 2005 Dont get the cheap ball joints, you dont want your wheel to snap on ya. Quote
mfewtrail Posted December 22, 2005 Report Posted December 22, 2005 The heavy duty suspension parts vs. normal are likely FE1 vs. FE3 parts. Quote
