5speedz34 Posted December 20, 2005 Report Share Posted December 20, 2005 Does anyone have the AC Delco fuel pump part number for a 88 2.8. 01 EP240 PUMP,FUEL First Design TO BE USED W/FUEL SENDER HARNESS LABELED WEC 07)(FOR 2ND DES SEE 25163468 DOES NOT INCL STRAINER. 01 EP378 PUMP,FUEL Second Design ELEC, TO BE USED W/FUEL SENDER HARNESS LABELED WEC 22)(REQUIRES STRAINER 25121637)(FOR 1ST DES SEE 25116162 Those are the 2 numbers I get, I want to say the 240 is for the 2.8, and the 378 is for the 3.1/3.4? Quote Link to comment Share on other sites More sharing options...
93CutlassSupreme Posted December 20, 2005 Report Share Posted December 20, 2005 you're putting a fuel pump into that car now? pump was fine while i had it Quote Link to comment Share on other sites More sharing options...
mfewtrail Posted December 20, 2005 Report Share Posted December 20, 2005 When I replaced the fuel pump in my 93/3.1 car, the EP378 was the part # for it. I would imagine your 1988 Cutty would have the 1st design/EP240, but someone else that knows for sure can answer that for you. Quote Link to comment Share on other sites More sharing options...
5speedz34 Posted December 20, 2005 Author Report Share Posted December 20, 2005 you're putting a fuel pump into that car now? pump was fine while i had it Well, there are some cheap ones on ebay for like $30, and I need to replace the fuel sender eventually, so I'll do that at the same time. When I replaced the fuel pump in my 93/3.1 car, the EP378 was the part # for it. I would imagine your 1988 Cutty would have the 1st design/EP240, but someone else that knows for sure can answer that for you. Yeah, that's pretty much what I'm thinking. Quote Link to comment Share on other sites More sharing options...
5speedz34 Posted December 20, 2005 Author Report Share Posted December 20, 2005 BUMP Quote Link to comment Share on other sites More sharing options...
5speedz34 Posted December 20, 2005 Author Report Share Posted December 20, 2005 Someone Quote Link to comment Share on other sites More sharing options...
