trick to reinstalling the oil pump drive shaft
I can't get the thing to go back in all the way. It needs to go down just a little bit more.. does it need tapped in, or should it just drop into place?
You just need to twist it and push it and it should drop in pretty easily. I wouldn't tap it in.
Shawn
so far i have been putting it in, then pulling it out, then turning it a small amount.. this requires more skill than trying to get a girl to orgasm...
on the times it drops in, i can feel it connect with the gear and slides in fine, but it is just not going in deep enough. it looks like maybe a 1/4 inch more or so that it has to go
Use the little metal brace that goes around it to push it down the rest of the way as you put the bolt in.
