Any good fix for wheelhop?
I was messing around the other night, and was cruising at about 20 MPH, and got on it. Yeah, had tons of wheelhop, so I didn't move as fast as I was hoping for. This was on completely dry pavement with my stock Z34 wheels and tires as well. So far the suspension is this car has been beefed up pretty damn well. The mods are as follows:
ST front lowering springs with KYB-GR2's
All new front suspension components (ball joints, strut mounts, tie rod ends, but I'm replacing the ball joints again)
Front GM STB
GMPP trailing arms
So... is there any cure for this, or am I putting out a decent amount of power??
This can be moved if not in the right section.
Find a cow and strap it to the hood, the added wieght will keep you on the road.
Oh yeah, find the cow they used in Twister, it's a celebrity and will get you more notice!
You're breaking traction momentarily?
Or a continuous slip-catch-slip-catch-slip-catch?
well.. the only thing i can think about in your situation is your tires are out of round/blance. get the tires balanced and see if that dosnt help. other then that. i have no idea why you would be hopping. i know you have a boss motor in there but not even 300+whp motors wheelhop in our cars.
ohh did you check tire air preasure?
It was a slip-catch-slip-catch situation. It was definately wheel hop, as I have felt it in my dad's 95 Impala before.
Engine mods as follows:
95 Crate engine
Heads shaved to increase compression 10.5:1
5 angle valve job
P&P intake and exhaust ports
Tranny mods:
3.73 gearing
shift kit
3000 rpm converter
Hd internals
So I definately know it's not the tranny slipping. It has less than 30,000 miles on it.
Air pressure was a bit on the low side. I haven't got on it recently, as the roads have been crappy due to horrible weather, but the tires are at proper psi right now.
Any other ideas?
my dad's Quad 4 5-speed car gets wheelhop if you 1-2 shift really fast...but then again his front struts are shot! :lol:
Hmm... I know my front suspension is good besides for one faulty balljoint, and its too damn cold to replace that right now(unless someone will be my friend and let me use there garage :wink: ).
I guess when I head up to Tony's(5speedz34) house this week, I'll bring my ball joint along.
Well I don't know what 300+whp w-bodies you've been driving, but the ones I've driven definately wheel hop and they do it at speeds in excess of 40mph.
The balljoint is not what is causing the car to wheelhop. You need to stiffen the rear suspension of the car to try to keep more weight over the front, the problem is probably truly that you have way to steep of a gear.
Shawn
Slick, any idea what that motor puts out at the crank and wheels?
No idea. Sometime in the spring i'm going to go over to Ben's to have it tuned and dyno tuned as well.
