Drilling through floor boards???
Ok, so I want to install an aftermarket dead pedal [it's a non-movable pedal placed the wheel well to the left of the brake pedal to rest your foot on] into my car. I want it on the hump of the wheel well on the dirvers side.
How would I go about removing the carpet to drill a hole into the wheel well? Is there any electrical things I have to watch out for?
Anyone do this before?
Guest Anonymous
If you take the trim off that runs along the drivers seat and goes partway up the door post, the carpet should pull back far enough.
I haven't done what you are talking about, but it would be very easy to move the carpet back to access just the wheel hump on the drivers side. The long trim piece that runs along the kick panel is held in with one screw and then clips. Remove the screw...peel the strip up and you have access to peel the carpet back. Easy as that. You will see any electrical under the carpet once you peel it back... 8)
This is what you will see under the carpet...another photo from the 5-speed project... :wink:
