Bg
ManicMechanic
I'm not getting any power to the turn signal switch for the brake lights. Shouldn't the 4 ways be cancelled out when the brake lights come on? Mine don't...
No, they override the brake lights just as the turn signals do Only the third brake light stays lit.
is the third brake light working?
and are the brake lights working normally when hazards are off?
Is it a brand new switch?
Did you verify that the third brake light bulbs are good?
and did you say that the lights DO come on if you hit the wiring connector that goes to the brake lights from the switch with power?
oh. shucks. please let us know what the problem was... It's probably something stupid like a broken wire.
Make sure that they know that the turn signal switch and brake switch are new so they don't try to fix those!!!!
