FordBoy Posted December 16, 2005 Report Posted December 16, 2005 with my '89 cutlass supreme int. I have gone though 2 radios the stock tape player and a cd player neither 1 of them can pick up any radio stations it is pissing me off i checked some of the wiring im just wondering if i need a new antenna Quote
Pabz Posted December 16, 2005 Report Posted December 16, 2005 New antenna, my 89 sucks ass, my converible has a way better one, I dont know where i can pick one up from??? Quote
DiscoStudd Posted December 16, 2005 Report Posted December 16, 2005 It might be something as simple as soldering on a new connector on the end of the antenna cable where it connects to the radio. Also, check the cable's connection at the antenna itself to see if it's still in tact. Quote
Regal_GS_1989 Posted December 17, 2005 Report Posted December 17, 2005 It might be something as simple as soldering on a new connector on the end of the antenna cable where it connects to the radio. Also, check the cable's connection at the antenna itself to see if it's still in tact. Yea, the antenna it self just doesn't Go bad, unless it breaks or something. I had a reception problem on my regal, and I had horrible static on FM when my blower motor was on. I had to change my blower motor, and ended up breaking an adapter that was between the antenna and my radio. I soldered it back together, and now its perfect. Pulls in FM stations from around 100 miles away too :shock: Quote
Crazy K Posted December 17, 2005 Report Posted December 17, 2005 it's an antenna cable problem. try the above or strip one from a junk car. Quote
