Pabz Posted December 16, 2005 Report Posted December 16, 2005 Went on a walk through the junk yard, had no tools, found a couple set of headlights for HID retro fit. Anybody want any cutty lights, 20 bucks each. Good condition. Main question is i found a 90? (production date 11/89) cutlass supreme sedan international. It had a black dash pad and console, the doors and all plastic trims were black and black vinyl(pleather) on the door panels. Was this stock or did someone go to town with black paint. I am getting this for the vert. going with black leather interior, Steering wheel is black to with steering wheel controls, would a crappy steering wheel remover work, and how to get steering wheel out without busting it up. Lots of ECC's too. how should i take the interior thermo out. I wanna upgrade the 89 with this. Also found a euro 3.4, it has front pass side damage, its sitting on the subframe, do you think it would be easy to get the 34mm sway bar out. All DOHC's came with one right? What sockets sizes do I need? 2 brackets on each side? Anybody want anything while I am freezing my ass off. Also wanna put buckets in the back of the conv, could i just grab them from another cutty. Ive taken a dash out before but knowing socket sizes and location and number of screws, bolts would be great. Quote
digitaloutsider Posted December 16, 2005 Report Posted December 16, 2005 Main question is i found a 90? (production date 11/89) cutlass supreme sedan international. It had a black dash pad and console, the doors and all plastic trims were black and black vinyl(pleather) on the door panels. Was this stock or did someone go to town with black paint. I am getting this for the vert. It's stock. I can guarantee you spray paint never met the inside of that car. Quote
Pabz Posted December 16, 2005 Author Report Posted December 16, 2005 Any one got any pics of where this would be, general location fan speed control with wiring harness (behind fan motor, under dash) Quote
Guest TurboSedan Posted December 16, 2005 Report Posted December 16, 2005 Main question is i found a 90? (production date 11/89) cutlass supreme sedan international. does that car have the BYP body 'gfx' pieces? it's the black plastic strips that run under the front/rear bumper and along the sides. i need some of those :shock: i haven't been able to find anything at the j/y around here and the ones on my car are in very poor shape. i once tried to get that fan speed conrol out for the ECC. i gave up, and in the end deleted A/C anyway. i couldn't figure out how to get that thing out :oops: good luck Quote
Pabz Posted December 16, 2005 Author Report Posted December 16, 2005 Main question is i found a 90? (production date 11/89) cutlass supreme sedan international. does that car have the BYP body 'gfx' pieces? it's the black plastic strips that run under the front/rear bumper and along the sides. i need some of those :shock: i haven't been able to find anything at the j/y around here and the ones on my car are in very poor shape. i once tried to get that fan speed conrol out for the ECC. i gave up, and in the end deleted A/C anyway. i couldn't figure out how to get that thing out :oops: good luck got any pics, are they on your car in your sig?? Any idea on how they are mounted. I'll take some pics and charge whatever they charge + shipping, no freezing my ass of charge! Quote
Guest TurboSedan Posted December 16, 2005 Report Posted December 16, 2005 yeah you can see them in my sig. they are the black plastic things that hang down below the body by about 1". they are really easy to remove, just need a phillips screwdriver IIRC. there is one piece per side, another for the front bumper, and the rear 'wrap' is either two or three pieces depending on weather it has single or dual exhaust. thanks!! Quote
Dirty Rockstar Posted December 16, 2005 Report Posted December 16, 2005 Did the Euro have the red bowtie chenter trim panel? Also want the 3.4 badges please! 8) Quote
pwmin Posted December 16, 2005 Report Posted December 16, 2005 sway bar: outer nuts: 15/16", inner bolts: 15mm interior: should be 7mm or 1/4" maybe some 10mm's, maybe T15, and proably phillips. may be more but thats usually it. Quote
Pabz Posted December 16, 2005 Author Report Posted December 16, 2005 Did the Euro have the red bowtie chenter trim panel? Also want the 3.4 badges please! 8) center trim panel in the interior?? want the 3.4 badge and euro part too, or are they one piece. Quote
Dirty Rockstar Posted December 16, 2005 Report Posted December 16, 2005 Just lookin for the 3.4 badge.. As for the trim panel, it is the one for the reverse lights.. Will either say "Chevrolet" or have a red bowtie.. Quote
Dirty Rockstar Posted December 16, 2005 Report Posted December 16, 2005 Just lookin for the 3.4 badges.. As for the trim panel, it is the one for the reverse lights.. Will either say "Chevrolet" or have a red bowtie.. Quote
White93z34 Posted December 16, 2005 Report Posted December 16, 2005 be careful pulling interior plastics in the winter, the likelyhood of breaking something plastic is increadibly high. Quote
GutlessSupreme Posted December 16, 2005 Report Posted December 16, 2005 would a crappy steering wheel remover work do a search under my name for steering wheel. you shouldn't need one. Quote
Pabz Posted December 16, 2005 Author Report Posted December 16, 2005 Lock plate compressor? what the hell is that? You don't need any special tools to do it. remove the pad on the front of the steering wheel. Remove the wheel nut. Place one knee under each bottom 1/4 of the wheel, and one hand on each top 1/4. Quick hard tug with all fours at once in the same direction will pull it off - just watch your head. I whacked mine pretty good :oops: The the switch itself is just a few torx bolts from there.. it's very easy actually. Running the new wire strand wouldn't be that hard, at least I didn't think it was. What if it doesnt pop?? i wanna be in and out, dont wanna get frost bite. What size torx screws for the turn signal switch. Think any issues with this stuff being from a sedan? Quote
White93z34 Posted December 16, 2005 Report Posted December 16, 2005 torx 15 or 20 as i recall, i want to say 15 though. Quote
Crazy K Posted December 16, 2005 Report Posted December 16, 2005 You can get a loaner steering wheel pulled if you need, from autozone or advanced. Dvanced seems to be a better quality. It's a cash deposit fully refunded when you return the tool. Quote
Pabz Posted December 16, 2005 Author Report Posted December 16, 2005 HELP, how the hell am i going to get the center console out if the car has no keys, cant move shifter??????????? Quote
Dirty Rockstar Posted December 16, 2005 Report Posted December 16, 2005 Take as much of the top out you can get.. Then, get a screwdriver and pry the cable and the other little thing off.. then the shifter should move.. Quote
Pabz Posted December 17, 2005 Author Report Posted December 17, 2005 Well I took the shifter handle off, and pounded it with a hammer to break it, and pulled. Worked like a charm. Got dash, left/right console ECC, DIC, and top of the center console. Front piece of steering wheel, Couldnt get the steering wheel off and the steering wheel remover bolts would not thread into the steeting wheel. What size threads??? Found a stock harness adapter for the radio and an antenna adapter. SCHWEET. Going back when tommorow when there is more light out. they almost forgot about us and left us in the yard :shock: $50 bucks. Quote
