Talisman Posted December 15, 2005 Report Posted December 15, 2005 That is me posting in the thread. Can you guys tell me if what he is talking about is a problem for my 95 coupe. http://www.xceedspeed.com/forums/viewtopic.php?t=36383 Quote
GutlessSupreme Posted December 15, 2005 Report Posted December 15, 2005 If they fit on his Lumina they'll fit on your Cutlass. You're right about the hubs being the same. Lumina's stayed the same through '99. Quote
Crazy K Posted December 15, 2005 Report Posted December 15, 2005 The center bore is the hole in the middle of the rim, the lumina/cutlass hubs may have a larger diameter protrusion on the face of their hubs. He may have had to use spacers to make them fit. Quote
Dannymik Posted December 15, 2005 Report Posted December 15, 2005 plus the rim bolt pattern is a 114.3, so spacers for them might be needed....the +38 offset should be ok. Quote
jeremy Posted December 15, 2005 Report Posted December 15, 2005 the bolt pattern wil fit, but you will probably have to grind the center bore a little bigger to get them to fit the rear.... Quote
GnatGoSplat Posted December 15, 2005 Report Posted December 15, 2005 You'll have to enlarge the center bore to fit AT ALL. The hub protrudes on front and rear. I wouldn't run a spacer on 38mm offset, that's just about right and a spacer would make them stick out too much. I've heard a machine shop can take care of that. I have the same problem with a set of wheels I bought to experiment with. 69.00mm and I need 70.30mm, ugh. Yeah, all W-bodies and pretty much all midsize GM's have a 70.30mm center bore. Quote
