imyourpusha Posted December 14, 2005 Report Posted December 14, 2005 Help! haha I just bought a 2001 buick regal gs and the driver side seat heater is not working. If it was passanger side I wouldnt mind that much but it makes it that much worse when your friend your sitting next to you is safe from hemroids and the car owner's ass is freezing. Does anyone know where to locate a wiring diagram for this so I can attempt to fix this! Any help would be appriciated! Quote
creepin_olds Posted December 16, 2005 Report Posted December 16, 2005 You are going to have to remove the seat and look under it, there should be a motor with about 4 wires coming out ( I think ) take that motor off and make sure it is getting fire to it, because with Regals seats, they had a bad problem with motor going out Quote
skiiirt Posted December 16, 2005 Report Posted December 16, 2005 Im scared the bravada will have the same problems in a few years Quote
sl3196 Posted December 17, 2005 Report Posted December 17, 2005 Heater element could be burnt out. You have both fronts heated right? (i dont stupid pontiac) Quote
1990lumina Posted December 17, 2005 Report Posted December 17, 2005 Check the switch as well...could be fucked up....see if there is any current draw through it. Quote
