92pontiac s.e. Posted December 13, 2005 Report Posted December 13, 2005 I went to start my 92 pontiac G.P. yesterday And it wouldn't start. It has the 3.4 d.o.h.c. engine,It turns over but it won't fire. I have absolutely NO idea what's wrong with it. I can smell fuel when i'm trying to start it,So i don't know if it's dumping excess fuel for whatever reason,something wrong with the fuel pump,e.t.c.,It's been quite awhile since the car had a tune up.Thanks for any and all help. Quote
DiscoStudd Posted December 13, 2005 Report Posted December 13, 2005 Crank sensor, coil packs, and/or the Ignition Control Module (ICM) are the usual suspects. Replacing the Coil Packs and ICM as one complete unit is a good place to start. You can usually get the complete assembly from a boneyard for around $50... Quote
92pontiac s.e. Posted December 13, 2005 Author Report Posted December 13, 2005 Thanks for the help of course this would happen after i spend $$$ on something else Quote
pwmin Posted December 13, 2005 Report Posted December 13, 2005 always does. at least they arent too expensive. you may even be able to see corrosion on one or more of the packs and/or the icm Quote
