AWeb80 Posted December 13, 2005 Author Report Share Posted December 13, 2005 Ok, so when i plug the headlight switch in yes the HUD and DIC do work then..... I also forgot, the headlights don't turn on...but the parking and fogs do....? WIth just the key turned forward, no car running And i've got some wierd items showing on the HUD.....i've got :NO lights on :NO Blinkers on :and half a tank of gas why does this still have them showing? Quote Link to comment Share on other sites More sharing options...
supreme_style21 Posted December 13, 2005 Report Share Posted December 13, 2005 Ok, so when i plug the headlight switch in yes the HUD and DIC do work then..... I also forgot, the headlights don't turn on...but the parking and fogs do....? WIth just the key turned forward, no car running And i've got some wierd items showing on the HUD.....i've got :NO lights on :NO Blinkers on :and half a tank of gas why does this still have them showing? What do you have plugged in and turned on when it shows this? How old are your battery, alternator, and turn signal switch? Quote Link to comment Share on other sites More sharing options...
AWeb80 Posted December 13, 2005 Author Report Share Posted December 13, 2005 What do you have plugged in and turned on when it shows this? How old are your battery, alternator, and turn signal switch? I have the HUD Switch and the headlight swith plugged in and key turned to accessory. the Dic and Hud both work...and also when i turn right, the left hud signal blinks and vice versa Quote Link to comment Share on other sites More sharing options...
supreme_style21 Posted December 13, 2005 Report Share Posted December 13, 2005 What do you have plugged in and turned on when it shows this? How old are your battery, alternator, and turn signal switch? I have the HUD Switch and the headlight swith plugged in and key turned to accessory. the Dic and Hud both work...and also when i turn right, the left hud signal blinks and vice versa Geez odd. How old is your turn signal switch? The one inside the column. Has that switch given you ANY problems yet? Quote Link to comment Share on other sites More sharing options...
supreme_style21 Posted December 13, 2005 Report Share Posted December 13, 2005 Have you tried plugging in your ORIGINAL good headlight switch in along with the NEW HUD switch? Quote Link to comment Share on other sites More sharing options...
AWeb80 Posted December 13, 2005 Author Report Share Posted December 13, 2005 NO problems with turnsignal....but you prolly jinked me... Ya, tried original switch and new one....i think this might be a problem though Look at the rotating switch connections Quote Link to comment Share on other sites More sharing options...
supreme_style21 Posted December 13, 2005 Report Share Posted December 13, 2005 Can't see anything outstanding there, but I haven't pulled THAT apart that far yet to be able to tell what you're pointing at. Quote Link to comment Share on other sites More sharing options...
99RegalGS Posted December 13, 2005 Report Share Posted December 13, 2005 I have the HUD Switch and the headlight swith plugged in and key turned to accessory. Ummmm, I don't think our HUD is suppost to come on in the accesory position. All the one's I've seen haven't. Quote Link to comment Share on other sites More sharing options...
GP1138 Posted December 13, 2005 Report Share Posted December 13, 2005 I have the HUD Switch and the headlight swith plugged in and key turned to accessory. Ummmm, I don't think our HUD is suppost to come on in the accesory position. All the one's I've seen haven't. Somehow, something's crossed. Did you get a '96 HUD/DIC? Is your car a '96? I know the '95 and '96 DIC's weren't compatible, but I don't know about the HUD's. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 13, 2005 Report Share Posted December 13, 2005 The more and more i read this, it almost sounds like your HUD unit is bad if its displaying the icons for no reason. Also, Did you plug the HUD in backwards? When you turn it to the acessory or whatever, it should display the battery and oil temp icons. Somethings wrong. I'd check to see if its plugged in right. Quote Link to comment Share on other sites More sharing options...
AWeb80 Posted December 13, 2005 Author Report Share Posted December 13, 2005 The more and more i read this, it almost sounds like your HUD unit is bad if its displaying the icons for no reason. Also, Did you plug the HUD in backwards? When you turn it to the acessory or whatever, it should display the battery and oil temp icons. Somethings wrong. I'd check to see if its plugged in right. I got everything from Heza and he said he got it from a guy who had a 94.... and yes the hud is in correctly...it only plugs in one way. Does anyone have any wiring diagrams for the HUD?....i'd like to double check the wires and see if some are crossed....i might just unhook them....i'll do all this when i get the new switch....i'll see if that is the problem....and i'll get a new hud switch too. If only the MPH worked, that would be ok with me....i don't (need) the others..... Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 13, 2005 Report Share Posted December 13, 2005 I find it very ironic that you, who was very skeptical about this project, has encountered so many problem with something that is a 5 minute job. Its not your headlight switch(the icons part), maybe either you HUD is wired wrong (factory error) or the HUD unit is bad. Quote Link to comment Share on other sites More sharing options...
AWeb80 Posted December 13, 2005 Author Report Share Posted December 13, 2005 I find it very ironic that you, who was very skeptical about this project, has encountered so many problem with something that is a 5 minute job. Its not your headlight switch(the icons part), maybe either you HUD is wired wrong (factory error) or the HUD unit is bad. I know, i want to check the wiring,.....where do i find a wiring diagram? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 13, 2005 Report Share Posted December 13, 2005 theres one floating around on clubgp... ine one of the recent HUD threads. Quote Link to comment Share on other sites More sharing options...
AWeb80 Posted December 13, 2005 Author Report Share Posted December 13, 2005 U find it for me please.... Quote Link to comment Share on other sites More sharing options...
pwmin Posted December 13, 2005 Report Share Posted December 13, 2005 yeah, with accessory on, it turns on and displays oil and batt lt. and 0, but as soon as you turn the park lights on, it goes off. HTH here? Quote Link to comment Share on other sites More sharing options...
AWeb80 Posted December 13, 2005 Author Report Share Posted December 13, 2005 http://bcaudio.com/TB/HUDConvesionwiring.xls not sure if that helps...? Quote Link to comment Share on other sites More sharing options...
pwmin Posted December 14, 2005 Report Share Posted December 14, 2005 you can always pm brian. hes always willing to help with diagrams and such. thx cpt. obvious Quote Link to comment Share on other sites More sharing options...
