@$*@$@$&# LIM!!11FIVE
digitaloutsider
I'm posting this in powertrain because the W-bodies share this engine too. The 3400 in the Montana has a leaking LIM. There's coolant in the oil, and it looks like a milky sludge (seen it many a time before). All I really need to know is what gasket people use most (Felpro, GM OEM, etc.) and what other parts or speciality tools are required.
Thanks guys.. :(
Felpro has worked fine for my valve covers, but I don't know about head/intake gaskets since I haven't had to do that work yet.
Thanks guys.. :(
GM oem, because they have corrected the LIM problem now
Felpro also updated thier design to fix the cracking issue however they took a different approach. GM uses metal tabs around the bolt holes in the gasket to prevent cracking from over torquing (the reason for the cracking). Felpro used a different kind of plastic for the frame and made it a bit beefier in those areas.
Both styles make use of a revised rubber/urthane material for the seal. You can use either but I would stick with GM. Also be sure to get the revised LIM bolts annd have a GM tech print the TSB for you which has the revised torque spec and procedure.
Have fun.
Bought the gasket kit and bolts from GM. Set me back about $125. I'm gonna get ahold of my buddy who has his own garage. I'm not doing this in my front yard. :lol:
Glad you bought the GM ones. Good luck with it.
i like the design of the GM ones, i'd like to see a set of felpro gaskets for comparision however.
I did mine in my parking lot. Took me about a 12 pack to get it finished.
The proper torque specs should be on a sheet with the intake gaskets.
well your average w-body has alot more room to work with then the cramped quaters that a u vans got so i can see that taking awhile longer.
Ah... crap, I was thinking this was his cutty. Guess I need to read more.
:lol: :lol:
Yeah.. it's in the damn Montana. Ughghgh.h,.ht,rhther,. I might get up the gumption to do it tomorrow.
Other than the wiper transmission getting in the way, and the alternator bracket bolts being barely visible w/o a mirror, it's not much harder. Been there done that. May wanna change out the spark plugs and wires if they haven't been done, at the same time since there'll be a good amount of extra room for the rears.
I hate this engine so much..
The only thing I hate worse than the 3400 right now is the stupid vehicle they decided to try and shove it in.
I've given up on this for now.. I don't have the patience to even look at that stupid POS at the moment. If this was in a Grand Am or something I wouldn't care. It's a nightmare in that goddamn U-van..
GM did update the design of the LIM gaksets after 1998 I think, and the new ones are much stronger. I've never used anything but the factory gaskets so that's all I can speak to.
try 2003, 99-2002 1/2 all have the problem, but the 2003+ grand ams dont
You don't have to pull the rear valve cover off to do a lower intake job.....this means the coil packs and alternator don't have to come off either.
If its a 'traditional' 3100 or 3400, the intake leaks. Haven't seen any of the Equinox or Z Malibu cars yet.
