Jcrow Posted December 8, 2005 Report Posted December 8, 2005 I would like if someone could post a picture of the top of a 3800 1st gen engine. I would like to know if the intake is the grand national / 3.0 style intake. Also is the transmission the same as a 3.1? Just a crazy idea I got in my head about dropping in a 3800 and putting my rebuilt grand national turbo on it and using a grand national computer. Quote
DiscoStudd Posted December 8, 2005 Report Posted December 8, 2005 I added the fender-to-core-support braces, as none of the L27-equipped Regals had them. My tranny is the 4T60-E, same tranny the 3100's received from 94-97 (or maybe 98 ) ... Quote
slick Posted December 8, 2005 Report Posted December 8, 2005 The 3.1 tranny will bolt up to the 3800. The exhaust manifolds for a turbo 3.8 MAY bolt up, but because that was a RWD set up, won't work for your application. I don't know too awful much as to what computer functions the GN's had, but I can almost bet it will not control your tranny almost at all. Quote
Jcrow Posted December 8, 2005 Author Report Posted December 8, 2005 i have the non-E trany so I only worry about it holding up. I can custom build the exhaust. The intake does look differant, but that is a '95 Quote
slick Posted December 8, 2005 Report Posted December 8, 2005 There are still a few electrical plugs that go into the tranny Quote
99RegalGS Posted December 8, 2005 Report Posted December 8, 2005 I added the fender-to-core-support braces, as none of the L27-equipped Regals had them. I did the same thing. Noticed a little bit of a change. The intake it seems that you're looking for is the LN3 3800 which is used from 1988-1991 (except Regals, which got the L27 in 1991). Also, you really don't need to use a turbo Regal Computer. Those engines are MAF only based fueling, so are early 3800's (untill 96 when a MAP sensor was added as a backup for the MAF). All you would need really is a reprogramed EPROM to change the ignition and fuel maps. Quote
Jcrow Posted December 8, 2005 Author Report Posted December 8, 2005 I added the fender-to-core-support braces, as none of the L27-equipped Regals had them. I did the same thing. Noticed a little bit of a change. The intake it seems that you're looking for is the LN3 3800 which is used from 1988-1991 (except Regals, which got the L27 in 1991). Also, you really don't need to use a turbo Regal Computer. Those engines are MAF only based fueling, so are early 3800's (untill 96 when a MAP sensor was added as a backup for the MAF). All you would need really is a reprogramed EPROM to change the ignition and fuel maps. That would be better, but I wouldnt know where to get the reprogramed EPROM Quote
ns87 Posted December 8, 2005 Report Posted December 8, 2005 Since I have a habit of asking somewhat related questions...how is that 3800? Does it have more of a high end powerband or lower end? Quote
Jcrow Posted December 8, 2005 Author Report Posted December 8, 2005 http://www.gmtuners.com It looks like he knows 3800's It looks like the best way to go would be a 4t-65 trans and a 3800 l36 with the turbo. And a OBD I gen 3 computer. Or I could just turbo my 3.1 and use a TGP chip. (only im concerned the chip may not work correctly with the bigger turbo.) Quote
chadz34 Posted December 8, 2005 Report Posted December 8, 2005 My grandpa's Olds Regency has a 3800 and it's got a gray engine cover instead of black???? Quote
TeeJay3800 Posted December 8, 2005 Report Posted December 8, 2005 My grandpa's Olds Regency has a 3800 and it's got a gray engine cover instead of black???? The LN3's Sean mentioned had the grey cover. As well as different heads and intake. Quote
DiscoStudd Posted December 8, 2005 Report Posted December 8, 2005 Since I have a habit of asking somewhat related questions...how is that 3800? Does it have more of a high end powerband or lower end?It has tons of low-end torque, and isn't too shabby on the top end either. The WAI I installed killed off a bit of low-end TQ, and didn't seem to help out too much on the top-end either. It just makes a cool sound, that's about it. I'm contemplating reinstalling the stock airbox with a K&N drop in, and running some 2 1/2" shop vac hose from the airbox's inlet to the air dam in the bumper. We'll see if I can manage to get a boost in both the high and low ends . My grandpa's Olds Regency has a 3800 and it's got a gray engine cover instead of black???? The LN3's Sean mentioned had the grey cover. As well as different heads and intake. The 91-92 L27's had a gray aluminum UIM (versus the 93-95's plastic UIM) and gray cover as well. Quote
TeeJay3800 Posted December 8, 2005 Report Posted December 8, 2005 The L27 is the better motor. Higher HP and TQ peaks with a much broader TQ band. The only advantage of the LN3 is the ultra low TQ peak (at only 2000 rpm), which makes it rocket off the line. LN3: 165 hp @ 4800 rpm 210 tq @ 2000 rpm L27 ('93): 170 hp @ 4800 225 tq @ 3200 Quote
chadz34 Posted December 8, 2005 Report Posted December 8, 2005 Yeah, my grandpa's car is a beast off the line (Regency), it can roast tires pretty well. But, other than that it's a dog. I liked the 3800 Series II Regal I drove, it was fairly quick. Felt just a little slower than my Z34. It's different having low end torque and no high end, than having no low end and high, high end. :? I just confused myself. Quote
Jcrow Posted December 8, 2005 Author Report Posted December 8, 2005 thats why turbos are good for engines with low-end torque and no high end torque Quote
94CutlassSLCoupe Posted December 8, 2005 Report Posted December 8, 2005 Yeah, my grandpa's car is a beast off the line (Regency), it can roast tires pretty well. But, other than that it's a dog. I liked the 3800 Series II Regal I drove, it was fairly quick. Felt just a little slower than my Z34. It's different having low end torque and no high end, than having no low end and high, high end. :? I just confused myself. you're probably right in that assumption. I will still say that our 3800 Series II '97 GP GT will probably still stomp our '94 CS Convertible with the LQ1 just because its hella quick off the line where the LQ1 is lacking. I was never that impressed with the 3800 Tuned Port. 3800 TPI W's seem to run the same 1/4 mile times as my 3100. If my 3100 takes a dump, I may just throw in a 3800 Series II for shits and giggles. Quote
chadz34 Posted December 9, 2005 Report Posted December 9, 2005 Oh yeah you can't go wrong with the 3800 Series II, it's a great engine. It will kill a 3.4 from a dig, but has virtually no chance on the highway. Quote
TeeJay3800 Posted December 9, 2005 Report Posted December 9, 2005 Oh yeah you can't go wrong with the 3800 Series II, it's a great engine. It will kill a 3.4 from a dig, but has virtually no chance on the highway. What makes you think the 3.4 will kill the 3800? They have near identical horsepower at near identical rpm (5000 vs 5500). IF the 3.4 wins on the freeway, it wouldn't be by much. Quote
chadz34 Posted December 9, 2005 Report Posted December 9, 2005 I thought the 3800 made higher numbers at lower rpm's than the DOHC. And, I thought the DOHC made more power in the high rpm's. I guess they really aren't that different then. Quote
TeeJay3800 Posted December 9, 2005 Report Posted December 9, 2005 You're right, the DOHC is known for top-end breathing, where as the 3800 is known for low-end and a broad torque band. However, the 3800 Series II is one pushrod that has decent high RPM performance. The 3.4 definitely has the advantage over 5500, but that's where a stock LQ1 starts to run out of gas too. It's hard to say who would win a freeway race. The 3.4 definitely has higher RPM performance potential however... Quote
94CutlassSLCoupe Posted December 9, 2005 Report Posted December 9, 2005 Its my opinion that the 3800 series II killed any chance of the LQ1 surviving longer than it did because its cheaper to produce and provides better performance (actual 1/4 mile times are similar, but the 3800 does better at part throttle, is cheaper to build, more relable, and gets much better gas mileage). Our GP's 3800 series II feels like it has a torque curve as flat as a flight deck on an aircraft carrier Quote
chadz34 Posted December 9, 2005 Report Posted December 9, 2005 Well let me tell you, it would be a close race between a 3800 Series II and a 3.4 DOHC, the Regal I drove, HAULED ASS. I was suprised. You won't be hearing me diss a 3800 Series II anymore, shocked me. It would be a good race. Quote
