patgizz Posted December 6, 2005 Report Posted December 6, 2005 i throw my stuff in the blasting cabinet after i clean it in the solvent tank slick knows all about the toys in my garage, he did his intakes here. Quote
Pabz Posted December 6, 2005 Report Posted December 6, 2005 Ok its not the magnaflux, they use a jet washer. Should do the job for cheap though. http://circletrack.com/techarticles/9817/ Quote
slick Posted December 6, 2005 Report Posted December 6, 2005 Bead blasting is definately the way to go, if you have the availability to get it done (thanks Patrick!!). If not, I would do what Josh did and get Brakeleen and tons of wire brushes. Hell... If you have to, get a small rubbermaid tub, spray the brakleen, let it sit for a few hours, then come back to clean it. Should make cleaning it much easier. If your coolant bypass tube is salvageable, sand it, and paint it with some high temp engine paint. If not, then get a new one. Quote
J Posted December 6, 2005 Report Posted December 6, 2005 slick knows all about the toys in my garage BWHAHAHAHAHA Quote
