Pyle Posted December 4, 2005 Report Posted December 4, 2005 I was hoping to find my OP so I could add to it, but anyway. I know what is wrong with my ABS, need a new harness. I was told to try and clean the connection first, how? Is there a solvent of some sort, or just scuff them up a bit? Also, if that works, will the lights go off and the ABS magically start to work, or do I have to go in and have the codes reset? Quote
Crazy K Posted December 4, 2005 Report Posted December 4, 2005 Those are the threads you already started this problem on, Please don't start a new thred everytime. IF you need to locate something you have done, you can click on your name (ex: displayed at the bottom of the forum main page, once you have logged in, and there will be a link for previous posts.) http://www.w-body.com/forum/viewtopic.php?p=439556&highlight=#439556 http://www.w-body.com/forum/viewtopic.php?p=416290&highlight=#416290 Edit: wasn't trying to be rude, just that the question asked was already answered on the other threads as well. Quote
EurosportZ34 Posted December 6, 2005 Report Posted December 6, 2005 hey, watch it there newb-hating newb! we aren't all w-body.com forum savvy as yourself. i'm sure you weren't a 100% forum literate on your first couple posts either. he pry just wants to get his problem solved just like you would if you were in his position. anyways...here's a bump for ya Pyle Quote
94CutlassSLCoupe Posted December 6, 2005 Report Posted December 6, 2005 scuff them up...and get some contact cleaner and dielectric grease. The ABS *should* just start working on its own but otherwise, just disconnecting the battery for a minute would be sufficent to clear the codes. Quote
z34Phoenix Posted December 11, 2005 Report Posted December 11, 2005 ooohhhh :shock: this sounds like me! Im off to fix the ABS!!!!!!!!!!!!!!!!!!!!! cant wait! Quote
Pyle Posted December 26, 2005 Author Report Posted December 26, 2005 OK, this is wierd. I got the car in summer of '04 and the ABS/ trac has never worked once since then. Suddenly as of a couple weeks ago, I come out to jump in my car and the ABS and trac control system are working! They work for about a minute, usually when I shift from reverse to drive, and then stop working again. Since I got a car wash, with underbody flush (hey it's cold out I'm not handwashing when it's 10 out,) it hasn't worked. Could there have been something that got up there and formed a connection... salt perhaps. The mechanic told me it was a bad harness, not the sensor itself. Quote
White93z34 Posted December 26, 2005 Report Posted December 26, 2005 well pull teh wheel, unplug all the sensors, use a wire brush and mabie some kero, and clean up the connections then coat it in some dielectric grease and put it back together. Quote
