ssheen Posted November 26, 2005 Report Posted November 26, 2005 Hi, My wife's car, 94 Oldsmobile Cutlass Supreme SL is having ABS problems. The pads and calipers are new. The ABS seems to come on at times when it should not is the best way to describe the issue. How would I go about disconnecting the ABS? Any ideas on why it would be doing this? Quote
Crazy K Posted November 26, 2005 Report Posted November 26, 2005 PHANTOM ABS it is normally the result of a poor signal from a sensor. As the wheel slows the signal drops away and is lost. You can pull the abs fuse to stop it from happening, this disables abs and leaves you with normal brakes. But I recommend fixing the problem. It could be casued by resistance at a dirty connector. Try disconnecting each connector, cleaning them, and putting some dielectric grease on the metal tabs before snapping them in place. See if this corrects your problem. and give us an update on what you do. If it still happens,it can it be determined which wheel sensor is at fault I'd have the sensor replaced. - Ken Quote
birdman Posted November 26, 2005 Report Posted November 26, 2005 the sensors come off real easy, one bolt i think and are fairly cheap too. Quote
ssheen Posted November 27, 2005 Author Report Posted November 27, 2005 Thanks for the input guys. I will try to clean the connectors and see what happens. Is there anyway to tell if the sensors are bad which one? What other years and cars are the sensors on? I can go pull some from my local u pull yard. Quote
Crazy K Posted November 27, 2005 Report Posted November 27, 2005 One other thought.... I have sometimes seen a car run without brake pads, and doing so grinds the rotors and everything leaving a coating/deposit of powdered steel (aka rust ) all over everthing, including the sensor area. (aka my 95 Cutlass Supreme, no pads at the time of purchase!) I believe this can interfere with it's abs signals too! If you have a digital multimeter in the ohm setting, you could connect it to the abs sensor and slowly turn the wheel and compare the wheels to each other to see if one of the sensors is less responsive. but that would be a hard judgment call. Best to do is clean the sensors first, ensure no rust deposits are inhibiting the sensors and test drive, then let us know! - Ken Quote
ssheen Posted November 27, 2005 Author Report Posted November 27, 2005 Thanks for the further info Ken. Quote
ssheen Posted November 27, 2005 Author Report Posted November 27, 2005 What other cars and years would have the same sensors as the 94 Cutlass Supreme SL? Quote
Crazy K Posted November 27, 2005 Report Posted November 27, 2005 Basically any Grand prix(up to 96), regal(up to 97), lumina(up to 99) Monte carlo(up to 99), or Cutlass supreme(up to 97) with ABS will have the same sensors. (a good junkyard would know) Again, I would attempt to clean the sensors area of dirt/rust, and clean and grease the ABS sensors's connector first...(oh, watch for any damaged wires too.) before you start just replacing parts. - ken Quote
ssheen Posted November 27, 2005 Author Report Posted November 27, 2005 thanks for the info and advice Ken. Quote
ssheen Posted January 5, 2006 Author Report Posted January 5, 2006 I forgot to mention that I cleaned the front sensors and all was fine. Thanks again for that advice guys. Quote
jeremy Posted January 5, 2006 Report Posted January 5, 2006 I forgot to mention that I cleaned the front sensors and all was fine. Thanks again for that advice guys. Free fixes are always the best ones... Quote
Cutlassowner Posted June 10, 2024 Report Posted June 10, 2024 I have an 1994 Oldsmobile Cutlass Supreme S 3.1 with the same issue and been having it for years even with brakes I have tried everything to get this ABS lights to go out Could a shop check my ABS sensor to see if it could be cleaned? Quote
Schurkey Posted June 11, 2024 Report Posted June 11, 2024 7 hours ago, Cutlassowner said: I have an 1994 Oldsmobile Cutlass Supreme S 3.1 with the same issue and been having it for years even with brakes I have tried everything to get this ABS lights to go out Could a shop check my ABS sensor to see if it could be cleaned? Define "tried everything". WHAT did you "try"? What were the results? Yes, a shop can connect a scan tool to diagnose the problem. When it was MY W-bodies, the sensor wires were corroded, the sensor harness from wheel to chassis needed to be replaced. In other cases, the sensor may be bad, or the wheel hub. There are other potential problems that will require other solutions. That's why it needs to be diagnosed with the scan tool. When was the last time the brake fluid was flushed through the ABS unit using a scan tool to actuate the valves? Quote
Nick727 Posted June 16, 2024 Report Posted June 16, 2024 If you don't care about getting the ABS working and your brakes feel fine, Pull your instrument cluster and take the light bulb out of it for the ABS. Quote
rich_e777 Posted June 24, 2024 Report Posted June 24, 2024 Or hell who needs brakes, whatever you hit will stop you. You can snag a cheap ACTRON 3 with the GM cartridge that will read the ABS codes just fine but I cannot manipulate the master cylinder through it. Most shops probably wont have the OBD 1 tool needed but you can always call around and ask. Budget Brakes should as part of their inventory. If you can get the codes I`ll post the info from my manual related to them. Quote
josh Posted January 8 Report Posted January 8 I have a 1994 oldsmobile cutlass supreme sl and I can't get the drive side brake to bleed correctly and it still goes to the floor what else can I do???? Quote
Schurkey Posted January 12 Report Posted January 12 WHAT does "not bleeding correctly" actually mean? No end of air? No fluid flow? Leaks? Is the bleeder screw plugged? Is the bleeder screw on top, not on the bottom of the caliper? Quote
55trucker Posted January 12 Report Posted January 12 On 1/8/2025 at 4:42 AM, josh said: I have a 1994 oldsmobile cutlass supreme sl and I can't get the drive side brake to bleed correctly and it still goes to the floor what else can I do???? Seek considerably more experienced help, the life you save may be your own Schurkey 1 Quote
