snowboard_pro6 Posted November 26, 2005 Report Posted November 26, 2005 Hey guys in new here I just bought a 1991 Lumina Euro 2Door last weekend. It’s my first car and I wanna get this car to perform a lot more then it does. So far all I’ve done is put in a K&N filter. I was looking at putting a new thermo in so i can use the Hypertech Thermo Master Computer Chip. I live in Canada in an area that can range from 40degrees Celsius in the summer to -20degrees Celsius in the winter would my car be fine with a 180 degree thermo year round? Quote
birdman Posted November 26, 2005 Report Posted November 26, 2005 yea but you wont see much if any gains so if yours works i wouldnt touch it. Quote
digitaloutsider Posted November 26, 2005 Report Posted November 26, 2005 DO NOT, and I repeat, DO NOT BUY ANYTHING FROM HYPERTECH. Their chips are the biggest joke ever for the 60º family. Spend your money on the best-performing chip for the 60º's over at http://60v6store.com/ Sadly, there's not much you can do to make your car fast aside from boost. 3.1's are slower than piss, and nothing this side of a turbo is going to fix that. I'd save up for another car if I wanted power. You're sure as hell not getting it out of an LHO. Quote
Prospeeder Posted November 26, 2005 Report Posted November 26, 2005 Bah, cooler Thermostat isnt gonna do much anyway, mabye if you were boosted, and if it gets pretty cold there, it might decrease your heaters efficentcy, not worth it really Quote
THe_DeTAiL3R Posted November 26, 2005 Report Posted November 26, 2005 The only advantage to having a 180* in a 3.1 is it might keep the temp a bit lower in the summer, like stop-and-go traffic, that is all. If the one you have is fine I really wouldn't bother changing it (unless you decide on flushing your coolant). Check the FAQ section on "V6 mods for noobs" (or whatever it's called) Quote
snowboard_pro6 Posted November 27, 2005 Author Report Posted November 27, 2005 arite thanks for the info guys I’m going to look into getting that chip from 60* can these engines take nitrous? and if i use nitrous that means i can't change the timing with the chip? Quote
Supreme Cutlass Posted November 27, 2005 Report Posted November 27, 2005 There's one kit from nitrous oxide systems that should work well, but it specifically says in the instructions DO NOT INSTALL AN AFTERMARKET CHIP with it. Quote
digitaloutsider Posted November 27, 2005 Report Posted November 27, 2005 Nitrous.. 3.1.. oh god.. Quote
snowboard_pro6 Posted November 27, 2005 Author Report Posted November 27, 2005 guess thats a no, so i should go with the chip and underdrive pullies Quote
birdman Posted November 27, 2005 Report Posted November 27, 2005 definatly on the chip and some advise aginst pullies but i would do it if i had the money so its really up to you? Quote
digitaloutsider Posted November 27, 2005 Report Posted November 27, 2005 What's wrong with the UDP? I think the chip, dogbones, and UDP would be a good start. Quote
THe_DeTAiL3R Posted November 27, 2005 Report Posted November 27, 2005 Nitrous.. 3.1.. oh god.. Well this is a 3100, but still high 14's (with some other mods) isn't bad at all.... http://www.w-body.com/forum/viewtopic.php?t=31844 I'm thinking with a proper setup an otherwise stock 3.1 should run low 16s before blowing up... Quote
birdman Posted November 27, 2005 Report Posted November 27, 2005 What's wrong with the UDP? I think the chip, dogbones, and UDP would be a good start. all i sais was that some dont like them not me. im sure you've heard the ones who say it kills your accessories right? there fine and they get tested anyway Quote
sonyman87 Posted November 27, 2005 Report Posted November 27, 2005 DO NOT, and I repeat, DO NOT BUY ANYTHING FROM HYPERTECH. Their chips are the biggest joke ever for the 60º family. Spend your money on the best-performing chip for the 60º's over at http://60v6store.com/ Sadly, there's not much you can do to make your car fast aside from boost. 3.1's are slower than piss, and nothing this side of a turbo is going to fix that. I'd save up for another car if I wanted power. You're sure as hell not getting it out of an LHO. Why do people still bash Hypertech.. i use Hypertech comptuesr and t-stats. no problems they are super good imo.. just b/c 1 car did a test with all those chips dosnt mean you will have the same results.. just look how differently the 3.4dohc behaves in each car. its a totaly temperamental and will differ from each cars currnet tune. Quote
