over the past few days my ABS light would sometimes come on when i first start the car, i turn the car off, and turn it back on, no more ABS light, now today it came on and it will not go off, and as a result i have no ABS, i'd like to remedy this problem asap, and to do so pulling the ABS codes would be a nice start.
TechII Scanner.
I don't think there's any DIY way of obtaining ABS Codes unfortunatly.
okay, now do i NEED a tech I/II scanner to do this, or is there an equiverlant scanner that could work?
You can get ABS codes off the ALDL.
I set up a config that lets me get it with EFILive4.
You'll need a serial ALDL cable to use it though.
alright i like the sounds of that, where can i get EFI live 4? i should have no problem constructing the ALDL cable
a lot of competent scanners can do that, but its cheaper in the long run to do the other option obv.
  • 2 weeks later...
well looks like i don't need it now, my abs sorta fixed itself last night when i was playing with some of teh relays or whatever near that positive post, so i'm happy.
I was going to say it might be a relay, as a bad wheel speed sensor won't trip the light untill you start moving. My Regal had a sticking relay about a year ago, same thing was happening, just happened to tap on the relay and haven't had a problem since. :)
hmm good point! my 95 CS just started this crap with the abs light on from when it starts.
however, my brothers abs light turns on, but was apparently due to a worn alternator. But it turns on now maybe once a week when you start, shut it off and restart and it usaually goes away.
time to inspect these relays on both the CS's
