Supreme Cutlass Posted November 25, 2005 Report Posted November 25, 2005 My ignition coils are bone stock, would I see a big improvment if I change them out? What brand of spark plug wires should I use? DURALAST VALUCRAFT .... BOSCH? Which plugs should I use? AC delco rapidfires? or Autolite Double platnums? I've heard good things about both. Quote
Prospeeder Posted November 25, 2005 Report Posted November 25, 2005 Bosch wires should be fine, just dont use thier plugs, and AC delco rapid fires Quote
THe_DeTAiL3R Posted November 25, 2005 Report Posted November 25, 2005 My regular $3 AC Delcos looked just fine after I swapped them out with new cheap $3 AC Delcos, after 15,000km (first time I ever changed them since owning the car). Quote
gp90se Posted November 25, 2005 Report Posted November 25, 2005 Delco plugs, duracrap wires (lifetime warrenty, swap them every 2-3 years) Quote
dakiln Posted November 25, 2005 Report Posted November 25, 2005 I couldn't believe the ability of the Delco plugs to hold up. Changed the plugs last winter, it was the original set from 1994!!!!!! I know the prior owner, they had never had them changed. Went ahead and just put afctory wires in and compared with another Cutlass with duracrap wires and Delco plugs, my idles about twice as quitely, with the kid on the way I'll stick with what keeps it quiet Quote
Guest TurboSedan Posted November 25, 2005 Report Posted November 25, 2005 i just went to the GM dealer and picked up a set of ACDelco spark plug wires today. they cost $52, but i wouldn't consider anything else. well, except Magnecore KV-85s, but those would have been around $90/shipped :shock: Quote
EurosportZ34 Posted November 26, 2005 Report Posted November 26, 2005 AC Delco...is there any other replacement wire out there better? LOL!! Quote
Supreme Cutlass Posted November 26, 2005 Author Report Posted November 26, 2005 ...and what about coils? Quote
joey b Posted November 26, 2005 Report Posted November 26, 2005 I see no improvement in changing them. Quote
gp90se Posted November 26, 2005 Report Posted November 26, 2005 delcos have been proved somewhere they put out more power the the MSD replacement ones. don't know how true that is but the stockers do the job very well Quote
Guest TurboSedan Posted November 26, 2005 Report Posted November 26, 2005 for coils i would ONLY consider GM replacements! same goes for the ICM. Quote
Supreme Cutlass Posted November 26, 2005 Author Report Posted November 26, 2005 So in other words just keep the olds ones? Quote
