3.4L injectors?
Yes and it's recommended to replace pre-94 DOHC injectors with 94+ anyway. There was a problem with pre-94s that would cause stalling at low speeds and odd fluctuations in RPMs while cruising.
I got a set of '94 injec. from the wreakers and installing them as I speak,
I noticed the don't snap into the holes very good and the harness doesn't
fit well either. Do you know whats going on?
who? me: no, i used motor oil. the stock pcm wouldnt relearn them (50%incr from stock i might add. ill try them again when i get my dhp pt
I got my injectors installed/no leaks, must be ok. I noticed I have a miss now and a lack of power, could a injector be plugged or bad? How can you tell?
  • 2 weeks later...
