slick Posted November 22, 2005 Report Posted November 22, 2005 Got it off of WidGS, he had it sitting around from when he's done other downpipes. Anyways, question is, what color is what? I know 2 of them are grounds, one is from the actual O2 line, and the other is for the 12V Ignition. Anyone with a newer manual, much appreciated if you could look that up. Thanks. Quote
OldSkoolGP Posted November 22, 2005 Report Posted November 22, 2005 The 4-wire is a heated O2 sensor. You have heater power, heater ground, signal, and signal ground. IIRC, purple is the signal. I tried to run a 4-wire in my one wire setu once, it worked for crap, went back to one wire. Quote
slick Posted November 22, 2005 Author Report Posted November 22, 2005 Yep, figured out the purple is the signal, now just gotta figure out which is power. Guess I'll have to just test that with my extra battery. Quote
99RegalGS Posted November 22, 2005 Report Posted November 22, 2005 Red = heater power, Black = Ground, Purple = signal Quote
slick Posted November 22, 2005 Author Report Posted November 22, 2005 The colors on my pigtail harness are: Purple= which I am assuming is signal Tan=? Brown=? Brown=? I am assuming the browns are grounds, and the tan is the heater power. Quote
slick Posted November 22, 2005 Author Report Posted November 22, 2005 Welp, heading down to the basement right now to test it out. Quote
Pabz Posted November 22, 2005 Report Posted November 22, 2005 multi-meter that, ground to ground should be 0hms, no??? Heater element to ground should be high omhs. Quote
pwmin Posted November 22, 2005 Report Posted November 22, 2005 i assume thats correct...you shall see Quote
slick Posted November 22, 2005 Author Report Posted November 22, 2005 multi-meter that, ground to ground should be 0hms, no??? Heater element to ground should be high omhs. Should be, and I like your way of thinking. I kinda got sidetracked by working on another project(see General section), but I'm going to test this right now! Thanks! Quote
99RegalGS Posted November 23, 2005 Report Posted November 23, 2005 yes, I'd assume that tan is for the heater. and black for the grounds. DO not try to ohm out the signal wire to anything. I can kill the sensor that way. Quote
joey b Posted November 24, 2005 Report Posted November 24, 2005 what is the significance of this 4 wire sensor? Quote
Rocketman Posted November 24, 2005 Report Posted November 24, 2005 4 Wire O2 sensors have an internal heater that brings the sensor up to operating temp before the engine is warmed up. So its functional well before a single wire O2 sensor is. Quote
WildGS Posted November 24, 2005 Report Posted November 24, 2005 My guess is the two brown wires are the heater, Purple is the signal and tan is the signal ground. HTH This would be the plug on the car so the O@ sensor has the male end this is the female end. Quote
