Rocketman Posted November 19, 2005 Report Posted November 19, 2005 I'm ready to put my LIM back on, I've got the gaskets and everything. I searched but I could not find the answer to my question: Do you put RTV all over the gasket? or just on the ends of the valley? Thanks for the help, -Rocketman Quote
spacecadetz26 Posted November 20, 2005 Report Posted November 20, 2005 only on the valleys and the pointy corners of the valve cover gaskets where they meet the intake manifolds. Quote
GutlessSupreme Posted November 20, 2005 Report Posted November 20, 2005 Make sure you LOAD up the edges on the top of the block when you put it back on. My LIM on my 3.1 didn't even come close to touching the block, so you're gonna need a lot for a good seal. Make sure you get in the corners between the block and heads good too, as said. Quote
Guest TurboSedan Posted November 20, 2005 Report Posted November 20, 2005 like this: might want to use a little more than that even. mine doesn't leak at all, but if i had to do it again i would use a little more RTV. Quote
Rocketman Posted November 20, 2005 Author Report Posted November 20, 2005 Excellent guys, thanks a lot! Quote
Canada Posted November 22, 2005 Report Posted November 22, 2005 I don't use black RTV.......I use GMS.....its a grey type sealant.....GM calls it engine assembly adesive...it works really well. Quote
